william(at)wbliss.co.uk Guest
Posted: Wed Feb 24, 2016 3:05 pm Post subject: Monowheel brake caliper |
Hi all
I have noticed that the piston in the monowheel brake caliper overhangs
the edge of the brake disk. This may result in uneven wear on the pads.
Are there any other brake calipers (possibly using 2 smaller diameter
pistons) which can be used instead?
William Bliss G-WUFF
nigel_graham(at)m-tecque. Guest
Posted: Wed Feb 24, 2016 4:08 pm Post subject: Monowheel brake caliper |
The Europa caliper is a clone of the Cleveland and as such is used
successfully on thousands of planes without problems. What you DO need
to look out for is re-lined pads. If the rivets stand proud of the back
of the pads, they will contact the piston and cant the pads causing
uneven ware.
If you want a really classy wheel and brake combination, take a look at
the Beringer products:
http://www.beringer-aero.com/file/brg_catalogues/9/cata_fichier/1_europe-in-english.pdf
Page 9 for Europa Monowheel conversion.
It's lovely stuff, beautifully made and much lighter than the OEM.
Nigel
On 24/02/2016 23:04, William Bliss wrote:
Hi all
overhangs the edge of the brake disk. This may result in uneven wear
on the pads. Are there any other brake calipers (possibly using 2
smaller diameter pistons) which can be used instead?
flyingphil2
Posted: Thu Feb 25, 2016 2:38 am Post subject: Re: Monowheel brake caliper |
The Beringer kit does indeed look lovely stuff.
They have a kit for a mono but has anyone used their parts on a Europa tri-gear or conventional taildragger? Any idea what the weight saving would be?
dpark748(at)icloud.com Guest
Posted: Thu Feb 25, 2016 6:49 am Post subject: Monowheel brake caliper |
I would also be interested in the weight saving. Just replacing wheel tyre and disc and caliper on mains and nose wheel and tyre.
Dave G-LDVO
| Quote: | On 25 Feb 2016, at 10:38, flyingphil2 <flyingphil627-europastuff(at)yahoo.co.uk> wrote:
http://forums.matronics.com/viewtopic.php?p=453157#453157
Posted: Sat Feb 27, 2016 1:41 am Post subject: Monowheel brake caliper |
As a public service, I've just gone down to a very chilly workshop to
weigh these bits for you. I hope you appreciate the effort!
The Matco wheel (with bearings), disc and caliper weigh 2.917 Kg each
(5.834 Kg per pair).
The advertised weight of the Beringer equivalent is 1.977 Kg each (3.954
Kg per pair) for the lightweight 5.00 x 5 p/n RF-002
or 2.445 Kg (4.89 KG per pair) for the heavy duty 5.00 x 5 p/n RF-005
This would indicate a weight savings on the mains (I can't get to my
nosewheel to weigh it) of 1.88 Kg or 0.944 Kg depending on which option
you go for.
The Beringer also uses twin pistons as standard and is beautifully CNCd
and anodised as standard.
I can't see why these would not make a worthwhile replacement for a
standard tri-gear. I intend to use them on my "Conventional".
Nigel
On 25/02/2016 14:48, david park wrote:
Dave G-LDVO
Posted: Sat Feb 27, 2016 11:44 am Post subject: Monowheel brake caliper |
Thanks for info sounds like an expensive 4 pounds saving!!!
Dave G-LDVO
| Quote: | On 27 Feb 2016, at 09:40, Nigel Graham <nigel_graham(at)m-tecque.co.uk> wrote:
As a public service, I've just gone down to a very chilly workshop to weigh these bits for you. I hope you appreciate the effort!
The Matco wheel (with bearings), disc and caliper weigh 2.917 Kg each (5.834 Kg per pair).
The advertised weight of the Beringer equivalent is 1.977 Kg each (3.954 Kg per pair) for the lightweight 5.00 x 5 p/n RF-002
This would indicate a weight savings on the mains (I can't get to my nosewheel to weigh it) of 1.88 Kg or 0.944 Kg depending on which option you go for.
The Beringer also uses twin pistons as standard and is beautifully CNCd and anodised as standard.
I can't see why these would not make a worthwhile replacement for a standard tri-gear. I intend to use them on my "Conventional".
Nigel
> Dave G-LDVO
> Sent from my iPhone
flyingphil2
Posted: Sun Feb 28, 2016 2:10 am Post subject: Re: Monowheel brake caliper |
Thanks Nigel,
Your public service and time in the cold workshop is appreciated!
Phil
