Posted: Wed Mar 02, 2016 8:40 am Post subject: amerri-king A-350/Narco AT-50A (correction) |
At 09:04 PM 2/29/2016, you wrote:
| Quote: | Thanks.
The bare wire of the encoder seems no to fit anywhere, but it's usually ground wire. What's the difference with the Black one wich is also a ground wire ? |
The black, insulated wire is USUALLY a power/signal
ground having significance with the operations of
the device. A bare wire has to be a shield ground
for the harness. Do an ohmmeter check to see if
the bare wire has continuity (TO THE CASE OF
THE ENCODER) at the encoder end.
If so, then leave it unconnected at the transponder
end. OTHERWISE, connect it to the same ground
as the black insulated wire at the transponder
end.
