ceengland7(at)gmail.com Guest
Posted: Thu Mar 03, 2016 7:39 am Post subject: Wire length in aluminum airframes |
Bob, I'm in the midst of wiring my RV-7, & realized that I can't find an
answer in 'the book' for this question. In the book and articles you've
written, you mention total wire distance (out & back), referencing
fiberglass airframes. But how do you compute wire length when you're
using an aluminum airframe for ground return for things like landing
lights, pitot heat, etc? Can the return path be essentially ignored,
since the return 'conductor' is so massively oversized?
And just for the sake of discussion, would the answer change if it's a
steel tube fuselage (significantly higher resistance for steel, but
still massive)?
Charlie
Posted: Sun Mar 06, 2016 4:15 pm Post subject: Wire length in aluminum airframes |
At 09:40 AM 3/3/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com>
Bob, I'm in the midst of wiring my RV-7, & realized that I can't find an answer in 'the book' for this question. In the book and articles you've written, you mention total wire distance (out & back), referencing fiberglass airframes. But how do you compute wire length when you're using an aluminum airframe for ground return for things like landing lights, pitot heat, etc? Can the return path be essentially ignored, since the return 'conductor' is so massively oversized? |
Yes . . . assume it to be . . . for all practical
purposes . . . zero resistance ground.
| Quote: | | And just for the sake of discussion, would the answer change if it's a steel tube fuselage (significantly higher resistance for steel, but still massive)? |
Not significantly higher . . . your aluminum airplane
might measure a few milliohms stem to stern with
steel being perhaps 50% higher. Neigher instance
is significant in the grand scheme of things.
Having said that, ground currents at engine cranking
current levels should be brought to the most
significant adjacent structure.
