art(at)zemon.name Guest
Posted: Wed May 04, 2016 7:29 am Post subject: WTB Wiring Tools & Stuff |
Folks,
I was about to order tools but thought that I ought to check here first, and see if any of you want to shed an excess tool or two. So far, I know that I need:
- Wire stripper such as the Stripmaster that strips 16-26 AWG
- Coax connector crimper, specifically to put connectors on RG-58
I am part way through building a wire book so I don't have definite lengths for various kinds of wire but here is what I have so far:
- RG-58, roughly 70 feet
- 18 AWG red and black wire, a bunch
- 22 AWG (or so) signal wire, single strand, twisted pairs, whatever, a bunch more
- Faston connectors, solder type, a bunch
Let me know if I can help you clean out your basement
  -- Art Z.
http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
donvansanten(at)gmail.com Guest
Posted: Wed May 04, 2016 12:48 pm Post subject: WTB Wiring Tools & Stuff |
No tools for sale, but a few suggestions.
1 replace the rg58 with rg400. 58 IIRC is solid core and breaks easily from vibration.
2 replace solder on fast on with real AMP crimp on faston. The solder on are hard to keep the solder from wicking up the wire resulting in a hard point that will break from vibration.
Just my .02 cents worth. On May 4, 2016 8:37 AM, "Art Zemon" <art(at)zemon.name (art(at)zemon.name)> wrote: | Quote: | Folks,
  -- Art Z.
ceengland7(at)gmail.com Guest
Posted: Wed May 04, 2016 1:32 pm Post subject: WTB Wiring Tools & Stuff |
Neither is precisely correct. RG58 is available both solid & stranded, and crimps have stress risers just like soldered connectors. Crimps are a lot faster (and more expensive), though.
Date:05/04/2016 3:45 PM (GMT-06:00)
Subject: Re: AeroElectric-List: WTB Wiring Tools & Stuff
-- Art Z.
rene(at)felker.com Guest
Posted: Wed May 04, 2016 1:50 pm Post subject: WTB Wiring Tools & Stuff |
I would like to vote for the crimp. Properly done aircraft quality faston all but totally eliminate the stress risers and are much easier to get right for the normal person. I used a lot of Solder in my airplane and I worry about those connections much more than my fastons.   But there is a time and place for everything. Pick the best solution you can for each task.
Rene'
801-721-6080
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Wednesday, May 04, 2016 3:31 PM
Subject: Re: WTB Wiring Tools & Stuff
Folks,
-- Art Z.
Posted: Wed May 04, 2016 2:02 pm Post subject: WTB Wiring Tools & Stuff |
Please folks... I'm not trying to start arguments about construction materials or techniques. Unless you have self-installing cable or connectors... you know, the ones where you pour them onto the floor and drink beer while they assemble themselves into a flawless wiring harness.. pre-installed inside the airplane.
Seriously, I'm just looking to buy stuff, not debate anything.
  -- Art Z.
On Wed, May 4, 2016 at 3:45 PM, don van santen <donvansanten(at)gmail.com (donvansanten(at)gmail.com)> wrote:
No tools for sale, but a few suggestions. |
stein(at)steinair.com Guest
Posted: Wed May 04, 2016 2:31 pm Post subject: WTB Wiring Tools & Stuff |
Hey----we have those! All it takes is a small monetary consideration…    J
Cheers,
Stein
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Art Zemon
Sent: Wednesday, May 04, 2016 5:02 PM
……..Unless you have self-installing cable or connectors... you know, the ones where you pour them onto the floor and drink beer while they assemble themselves into a flawless wiring harness... pre-installed inside the airplane.
-- Art Z.
Kellym
Posted: Wed May 04, 2016 6:10 pm Post subject: WTB Wiring Tools & Stuff |
RG-58 comes in both versions, solid and braided. In most cases, properly
supported cable has next to no flexing. It is a fine, and much cheaper
solution for VHF frequencies unless there is a noise generator nearby.
Insulation material isn't as good as RG-400, and only single shield.
however I have seen many a type certified aircraft with factory original
RG-58 that is still performing fine.
However, for transponders, DME and GPS you need better materials, better
shielding because they are operating in the 1 Ghz freq range. RG-142 was
used for a long time, with, IIRC solid core.
RG-400 is braided, more flexible, lighter and well shielded.
Just depends on your budget and application. about 50 cents vs 3-4 bucks
a foot.
On 5/4/2016 1:45 PM, don van santen wrote:
| Quote: | No tools for sale, but a few suggestions.
from vibration.
<mailto:art(at)zemon.name>> wrote:
Folks,
* Wire stripper such as the Stripmaster that strips 16-26 AWG
* Coax connector crimper, specifically to put connectors on RG-58
* RG-58, roughly 70 feet
* 18 AWG red and black wire, a bunch
* 22 AWG (or so) signal wire, single strand, twisted pairs,
* Faston connectors, solder type, a bunch
-- Art Z.
http://CheerfulCurmudgeon.com/ <http://cheerfulcurmudgeon.com/>
myself, what am I? And if not now, when?" Hillel/
KCHD |
