jeff(at)westcottpress.com Guest
Posted: Wed Jul 06, 2016 12:29 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Okay... now that the fly off is complete and the first couple of oil changes are behind me it seems I need a crash course in keeping N410CF finely tuned. Over the last few flights the engine has been progressively more difficult to start. I've been experimenting with different starting techniques and was attributing the problems to that. The last trip out to the run up area it died at idle. I restarted, ran the engine up to 1700 rpm and leaned it out. The subsequent idle check was okay, but things aren't feeling quite right.
I'm running a stock Vans supplied YIO-540-D4A5 with dual slick mags and a slick start... Total time on the engine is 44 hours
I've not yet purchased a plug cleaning kit or a mag timing light and would love some input on what I should buy.
Jeff Carpenter
N410CF... Flying.
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
Tim Olson
Posted: Wed Jul 06, 2016 12:44 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Buy a buzz box, and a mag timing pin (you may not need that for a while).
Then definitely check your ground lean setting on your engine.
While idling, go mixture full rich, check the RPM. Lean it out
until it starts to die. It should raise in RPM before it dies.
See how much higher it goes than what you started at full rich.
You want 20 to 50 RPM rise, no more no less. The star wheel
on your throttle linkage arm is how you adjust it. Once you get
it close a couple clicks do make a difference so maybe start with
a few clicks but eventually you'll be down to ticking it one
or two.
If you use good starting technique both cold and hot starts
should be pretty easy. And if you screw up a hot start you
can always slightly flood it and then use the flooded start
procedure and get it going fairly easily.
On 7/6/2016 3:27 PM, Jeff Carpenter wrote:
| Quote: | Okay... now that the fly off is complete and the first couple of oil
Jeff Carpenter
N410CF... Flying.
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com <mailto:jeff(at)westcottpress.com>
818-861-7300
taildragon(at)MSN.COM Guest
Posted: Wed Jul 06, 2016 1:26 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Also, leaning during taxis and warm-up will help
Keep the plugs clean.
| Quote: | Subject: Re: RV10-List: Mag Timing/Fouled Plugs... that sort of thing
To: rv10-list@matronics.com
Date: Wed, 6 Jul 2016 15:43:29 -0500
--> RV10-List message posted by: Tim Olson <Tim@myrv10.com>
or two.
> Jeff Carpenter
> N410CF... Flying.
> Westcott Press
> 1121 Isabel Street
> Burbank, CA 91506
> jeff@westcottpress.com <mailto:jeff@westcottpress.com>
> 818============================================================
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV10-List
_-=
_-============================================================
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
Dave Saylor
Posted: Wed Jul 06, 2016 3:50 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Jeff, are using a retard mag, or an impulse coupling? If the timing slips on the retard points it'll get hard to start for sure. Check the retard points just like the mains, but they should opening at or just after 0*.
--Dave
On Wednesday, July 6, 2016, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
| Quote: | Okay... now that the fly off is complete and the first couple of oil changes are behind me it seems I need a crash course in keeping N410CF finely tuned. Over the last few flights the engine has been progressively more difficult to start. I've been experimenting with different starting techniques and was attributing the problems to that. The last trip out to the run up area it died at idle. I restarted, ran the engine up to 1700 rpm and leaned it out. The subsequent idle check was okay, but things aren't feeling quite right.
Jeff Carpenter
N410CF... Flying.
Westcott Press
1121 Isabel Street
Burbank, CA 91506
[url=tel:818-861-7300]818-861-7300[/url]
_________________ --Dave
KWVI |
Bob Turner
Posted: Wed Jul 06, 2016 6:49 pm Post subject: Re: Mag Timing/Fouled Plugs... that sort of thing |
It sounds like the engine has never been timed? Apparently (?) Lycoming expects the installer to check and adjust the timing. Several builders, including myself, have reported the mag timing was off, right out of the box.
I bought a "kit" buzz box (some soldering required) for less than $50, works fine. I can't remember where I bought the kit, sorry.
_________________ Bob Turner
RV-10 QB |
Kellym
Posted: Wed Jul 06, 2016 7:56 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
A mag timing box is not that expensive.
http://www.aircraftspruce.com/pages/to/enginetools/synchronizer.php
I don't with the small Slicks, but with the large Bendix S1200s that I
have, it is necessary to remove a mag to install the engine to the
engine mount. Obviously the mag has to be re-timed after re-installing.
On 7/6/2016 7:49 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=457828#457828
KCHD |
Posted: Wed Jul 06, 2016 8:55 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
I assume you meant to say "I don't know with he small Slicks...", but they do not have to be removed to hang the engine.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Jul 6, 2016, at 11:56 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
I don't with the small Slicks, but with the large Bendix S1200s that I have, it is necessary to remove a mag to install the engine to the engine mount. Obviously the mag has to be re-timed after re-installing.
> Bob Turner
> RV-10 QB
Kellym
Posted: Wed Jul 06, 2016 9:24 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Yes
On 7/6/2016 9:54 PM, Jesse Saint wrote:
I assume you meant to say "I don't know with the small Slicks...", but they do not have to be removed to hang the engine.
Jesse Saint
352-427-0285
>> Bob Turner
>> RV-10 QB
KCHD |
Posted: Wed Jul 06, 2016 9:42 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Retard mag... and the mags were timed with the help of a couple of A&P's with a buzz box before the first engine start. It seems to me that the retard points and main points of the retard mag move together... so if one is off time the other would be as well. Am I missing something here?
On Jul 6, 2016, at 4:49 PM, David Saylor wrote:
| Quote: | Jeff, are using a retard mag, or an impulse coupling? If the timing slips on the retard points it'll get hard to start for sure. Check the retard points just like the mains, but they should opening at or just after 0*.
--Dave
Jeff Carpenter
N410CF... Flying.
Westcott Press
1121 Isabel Street
Burbank, CA 91506
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
Kellym
Posted: Wed Jul 06, 2016 9:52 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
You are correct. Is there a way to test the Slickstart box? I assume
your mags are set to 25 degrees.
There are various methods to cleaning plugs. I prefer a dental pick to
remove lead balls, and rotating bottom plugs to top to keep them clean.
I'm an hour or two behind you on TT. I have one plug that seems
intermittent, but it tests okay as far as resistance and isn't fouled.
While my ignition is a pair of Bendix S-1200 mags I find fuel system is
most temperamental on starts. The engine wants to be rich on cold start,
and have found putting mixture full rich just before cranking gives a
quick start. Hot starts are another mystery. Boost pump on, mixture idle
cutoff until starting to crank seems to work, adding mixture slowly
while cranking. If not enough fuel when it fires it quits easily.
On 7/6/2016 10:40 PM, Jeff Carpenter wrote:
| Quote: | Retard mag... and the mags were timed with the help of a couple of A&P's
> just after 0*.
> --Dave
> Jeff Carpenter
> N410CF... Flying.
> Westcott Press
> 1121 Isabel Street
> Burbank, CA 91506
> 818-861-7300 <tel:818-861-7300>
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
KCHD |
Dave Saylor
Posted: Wed Jul 06, 2016 10:03 pm Post subject: Mag Timing/Fouled Plugs... that sort of thing |
No, that's correct, when you twist the mag relative to the engine it moves both sets of points together. It's probably worth checking even though they were set not too long ago.
But--the retard and the main points can be timed individually as well, relative to each other. As the points wear, their timing changes--probably close to equally but not necessarily. So it is possible to have the mains firing right at (25*?) and the retards firing at, and say, 10* after instead of 0. You can check that with a buzz box but to fix it the mag would most likely need to come off.
--Dave
| Quote: | Retard mag... and the mags were timed with the help of a couple of A&P's with a buzz box before the first engine start. It seems to me that the retard points and main points of the retard mag move together... so if one is off time the other would be as well. Am I missing something here?
--Dave
On Wednesday, July 6, 2016, Jeff Carpenter <[url=javascript:_e(%7B%7D,'cvml','jeff(at)westcottpress.com');]jeff(at)westcottpress.com[/url]> wrote:
| Quote: | Okay.. now that the fly off is complete and the first couple of oil changes are behind me it seems I need a crash course in keeping N410CF finely tuned. Over the last few flights the engine has been progressively more difficult to start. I've been experimenting with different starting techniques and was attributing the problems to that. The last trip out to the run up area it died at idle. I restarted, ran the engine up to 1700 rpm and leaned it out. The subsequent idle check was okay, but things aren't feeling quite right.
Jeff Carpenter
N410CF... Flying.
Westcott Press
1121 Isabel Street
Burbank, CA 91506
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
KWVI |
Lenny Iszak
Posted: Thu Jul 07, 2016 7:11 am Post subject: Re: Mag Timing/Fouled Plugs... that sort of thing |
Don't forget to check the mags for the Slick SB if you haven't yet.
Tim has an excellent mag timing writeup on his site.
Lenny
Tim Olson
Posted: Thu Jul 07, 2016 7:23 am Post subject: Mag Timing/Fouled Plugs... that sort of thing |
Like Bob, I did buy a build-it-yourself kit long ago.
It does work fine. But, that being said, the link Kelly
sent you is probably what I'd do if I were buying today.
With tweeter.
I don't remember what I paid, but I would just make it simple
and buy one.
On 7/6/2016 9:49 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
Bob Turner
Posted: Thu Jul 07, 2016 9:06 pm Post subject: Re: Mag Timing/Fouled Plugs... that sort of thing |
| Kellym wrote: | You are correct. Is there a way to test the Slickstart box?
Sure. Pull #1 plug, lay it on top of cylinder with ignition lead attached. Disconnect the starter wire. Carefully, slowly rotate prop until near #1 TDC. Turn on power, hold key on start (or jumper). Slowly rotate prop to TDC. You should see multiple sparks as the retard points open. If Slickstart isn't working, no spark. Use usual precautions around prop.
Edit. You need to use the plug that is attached to the mag that is powered by the Slickstart.
RV-10 QB |
Kelly McMullen
Posted: Fri Jul 08, 2016 5:32 am Post subject: Mag Timing/Fouled Plugs... that sort of thing |
That would assume #1 top plug is fired by the left mag. I would want to verify that. I was hoping there might be a simpler test.
-sent from the I-chip implanted in my forearm
On Thu, Jul 7, 2016 at 10:06 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
| Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=457892#457892
A&P/IA, EAA Tech Counselor
KCHD |
