Edwardoc
Joined: 20 Aug 2009 Posts: 8 Location: Kersey, CO 80634
Posted: Mon Jul 11, 2016 6:18 pm Post subject: Rear Crankshaft Expansion plug removal and install |
Anyone have experience or advise on removing a leaking rear expansion plug in a hollow crank. It is loose in the crank and needs to be removed and insert a new one. Any advice or experiences doing this procedure would be appreciated.
Gary.A.Sobek
Posted: Mon Jul 11, 2016 7:18 pm Post subject: Rear Crankshaft Expansion plug removal and install |
Is it possible that the one that is installed only needs seated?
I have a friend that had his 360 overhauled. When it came back, it flew
fine for about 100-hours then the prop would go to high RPM. The cause
was found to be the rear plug was not seated properly. A tool was
fabricated by one of his machinist friends and the plug was seated.
That was over 1,000 flying hours ago without any additional prop going
to high RPM without the blue knob being pushed forward.
On 07-11-2016 10:18 PM, Edwardoc wrote:
http://forums.matronics.com/viewtopic.php?p=458092#458092
ceengland7(at)gmail.com Guest
Posted: Mon Jul 11, 2016 7:28 pm Post subject: Rear Crankshaft Expansion plug removal and install |
On 7/11/2016 9:18 PM, Edwardoc wrote:
This might be what you're looking for.
http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201435%20(04-25-1986)/Conversion%20from%20Constant%20Speed%20to%20Fixed%20Pitch%20Propeller%20and%20Vice%20Versa;%20....pdf
