hgmckay
Posted: Sun Aug 21, 2016 12:01 pm Post subject: Brake Caliper |
I have a flat tire on one of the main gear wheels on my Allegro 2000. I want to remove the wheel without unscrewing the hydraulic brake line from the caliper and loosing the brake fluid. Can I remove the disc brake caliper from the disc leaving it attached to the hydraulic brake line and then remove the wheel? If so how do I do it?
Hugh G. McKay III
Allegro 2000
Rotax 912 UL
N661WW
Ph. 704-661-8271
email hgmckay(at)bellsouth.net
| - The Matronics Allegro-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
Description: |
 Download |
Filename: |
Hugh.vcf |
Filesize: |
79 Bytes |
Downloaded: |
542 Time(s) |
Brian Carpenter
Posted: Sun Aug 21, 2016 1:52 pm Post subject: Brake Caliper |
The wheel is a split wheel, after removing the bolts you just take off the outside half of the wheel. There is no need to do anything about the brakes at this time. I believe the bolts are number five metric
Brian
Sent from my Brian's iPhone
On Aug 21, 2016, at 13:00, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
Quote: | I have a flat tire on one of the main gear wheels on my Allegro 2000. I want to remove the wheel without unscrewing the hydraulic brake line from the caliper and loosing the brake fluid. Can I remove the disc brake caliper from the disc leaving it attached to the hydraulic brake line and then remove the wheel? If so how do I do it?
Hugh G. McKay III
Allegro 2000
Rotax 912 UL
N661WW
Ph. 704-661-8271
email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
<Hugh.vcf>
_________________ BRIAN N3081X |
ledson
Posted: Sun Aug 21, 2016 7:16 pm Post subject: Brake Caliper |
I've done this a number of times. All you have to do is remove the three bolts that attach the brake disk to the wheel. Then remove the cotton pin from the axle shaft, remove the wheel retaining nut and the wheel should pull right off the axle shaft. The caliper and brake disk stay in place.
Good luck!
Larry
Sent from my iPad
On Aug 21, 2016, at 4:00 PM, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
Hugh G. McKay III
Allegro 2000
Rotax 912 UL
N661WW
Ph. 704-661-8271
<Hugh.vcf>
brad(at)vision-technology Guest
Posted: Sun Aug 21, 2016 7:29 pm Post subject: Brake Caliper |
Same here... I leave the brake components in-place.
The toughest part can be breaking the tire bead free from the rim. (Better to stand on it, rather than be tempted to pry it apart with sharp-edged objects).
Brad
N221FA
On August 21, 2016 10:16:00 PM CDT, Larry Edson <larryedson(at)ymail.com> wrote: Quote: | I've done this a number of times. All you have to do is remove the three bolts that attach the brake disk to the wheel. Then remove the cotton pin from the axle shaft, remove the wheel retaining nut and the wheel should pull right off the axle shaft. The caliper and brake disk stay in place.
Good luck!
LarrySent from my iPad
Hugh G. McKay III
Allegro 2000
Rotax 912 UL
N661WWPh. 704-661-8271email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
<Hugh.vcf>
