Radio transmission problem
trigo(at)mail.telepac.pt
PostPosted: Thu Aug 25, 2016 3:55 am    Post subject: Radio transmission problem Reply with quote
Bob and all
A friend of mine has a Cessna 182 Skylane, and in the last flights ATC people complained that his transmissions were barely readable.
Trying to find out the problem, I tested with a small simple Tx tester, and it seems to be 5x5.
Then I tried with a handheld on the ground, some 300 ft away from the airplane, and it received very well.
What should I test further?
After those tests, I also noticed that the electric altimeter is getting interference (needle moves) when I press the PTT.
Further, since I don't find any nut there, can somebody explain how to uninstall the yoke mounted PTT switch?
Carlos
PostPosted: Thu Aug 25, 2016 4:29 am    Post subject: Re: Radio transmission problem Reply with quote
Check the radio antenna ground and check both ends of the coax for tightness and for corrosion.
Joe Gores
PostPosted: Thu Aug 25, 2016 9:03 am    Post subject: Radio transmission problem Reply with quote
At 06:53 AM 8/25/2016, you wrote:
--> AeroElectric-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt>
Bob and all
Check SWR on the antenna feedline AT THE RADIO.
It sounds like you've got a coax shield open at
one end. The hand-held from 300 feet way would
hear the ship's radio if then antenna were a
wet string. But your observation of heretofore
non-existent interference to panel mounted goodies
strongly suggests the cockpit is being flooded
with RF that is not being constrained INSIDE the
feedline.
