MikeP
Posted: Mon Sep 05, 2016 1:31 pm Post subject: Redux |
Ladies/Gents
I may need a small amount of redux for a repair on the tail wheel mounting.
Anyone have any suggestions as to where/who might have a some available?
Also the instructions on its use
spcialeffects
Posted: Tue Sep 06, 2016 4:55 am Post subject: Re: Redux |
Hey Mike. You can buy it here
https://www.silmid.com/products/re420200ml-araldite-420-epoxy-adhesive-200ml-cartr.aspx
This is the smallest amount you can buy and you will need the gun too. If your asking "How to use it" then you obviously didn't build your aircraft so i would talk to your inspector for guidance on the "problem" and he will point you in the right direction reference the repair
Regards Frank
JohnFrance
Joined: 17 Sep 2014 Posts: 83 Location: Grenoble France
Posted: Wed Sep 07, 2016 2:42 am Post subject: Re: Redux |
Mike,
I purchased the Araldite 420 here, (but they don't show the small twin tube version at the moment, suggest you call them.)
http://www.mouldlife.net/araldite-420-ab-14kg-kit-2841-p.asp
And the data sheet is here,
http://www.mouldlife.net/ekmps/shops/mouldlife/resources/Other/420-data-sheet.pdf
I used it without the gun by pushing each cylinder individually and weighing the two components with precision scales. I didn't use the mixing nozzles as you need to mix a "certain quantity".
Regards, John
_________________ Europa mono Nr 192 |
