Posted: Sat Dec 03, 2016 7:58 am Post subject: Avionics Master |
| Quote: | Comments/Questions: Bob ... I took our seminar many years ago and you suggested not to use an Avionics Master .. that you can just turn on each component etc. So that's what i did .. and it's worked just fine. However, I'm now redesigning my panel with remote mount avionics .. COMM, TRANSPONDER, AUDIO PANEL etc. Now I'm curious how I should protect these during start up? Should I now plan for a MASTER or do I have to use individual switches for each component?
Thank you for your expertise!
Dave
The avionics master switch was borne of an idea not
grounded in physics. I was at Cessna in the 60's when,
for reasons we didn't understand, radios were being
killed in brand new airplanes by the dozens. Adding
the AV Master did indeed 'help' but for reasons we
did not know.
Check out the writings on my website concerning
the AV Master.
http://tinyurl.com/mr2jk8g
If you ever get to OSH, it would be interesting
to stop by the booths of the manufacturer of ANY
solid state device be it radio, instrument, system
controller, etc. and inquire as to their recommendations
for 'protecting their product from the effects of
engine cranking'.
If any one of them says that an AV Master is recommended,
I'd like to hear about it. Since the universal adoption
of DO-160 protocols about 50 years ago, risks to electronics
from startup transients (or other any well understood
transients) has gone to zero.
Turns out that the 'radio killer' in the 1960's Cessnas
was soggy batteries combined with poor design rules
for the radio's newly minted solid state power supplies.
That combination of shortfalls was easily and has been
eliminated.
donjohnston
Posted: Tue Dec 06, 2016 5:47 am Post subject: Re: Avionics Master |
Not to poke a sleeping bear...
I've got an avionics master not because I'm worried out spikes. My concern is with the opposite. Sags.
I also have remote avionics (no power switches on the devices) with a VPX power distribution system. When I'm starting up the EFIS will reboot if the voltage gets too low (I'd have to check the doc's but I think it gets unhappy below 18 or maybe 20v). The radios are a bit more tolerant as they will handle much lower voltages. Not sure about the GPS or audio panel.
The greater issue is that when the EFIS power sags, sometimes it won't reboot and just goes into limbo. Then I have to go in to the VPX, shut off the breaker, wait, and then reactivate the breaker to get the EFIS back up.
The EFIS doesn't reboot on every start. But if I've been fighting a stubborn hot start then the battery can get a little tired. For the primary EFIS, I have a small backup battery that powers the EFIS that during engine starts.
I could have put in a second backup battery for the other EFIS, or a switch for the second EFIS. But it seems like the simplest solution is an avionics master. This also allows me to power up the electrical system if I want to work on the gear retract system, lights, etc., without powering up the avionics.
Just my .02
Posted: Tue Dec 06, 2016 8:25 am Post subject: Avionics Master |
At 07:47 AM 12/6/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
I also have remote avionics (no power switches on the devices) with a VPX power distribution system. When I'm starting up the EFIS will reboot if the voltage gets too low (I'd have to check the doc's but I think it gets unhappy below 18 or maybe 20v). The radios are a bit more tolerant as they will handle much lower voltages. Not sure about the GPS or audio panel. |
Low voltage is generally not a stress to be
'handled' beyond the ability to make a graceful
recovery after the brown-out event. This
shortcoming is generally limited to devices
with micro-controllers that are not fitted
with brown-out protection features . . .
Failure to design such features into a modern
appliance is something akin to forgetting
to include a filler-spout on a fuel tank.
Pretty elementary.
In 50+ years of designing and fabricating
electro-whizzies for aircraft from Hawker
4000 to ultra-lights, I've never been
challenged by the notion that brown-outs of
any magnitude, rate and duration are a
special force to be wrestled with.
Just my .02 |
Unfortunately, there are numerous products offered
to the aviation markets that are not designed to the
spirit and intent of legacy rules-of-the-road for
aviation appliances.
Brownout mitigation has been discussed numerous
times over the years here on the List with a
variety solutions offered. They all have the
disadvantage of increased weight, system
complexity and potential electro-magnetic
compatibility issues (radio noise).
Do these affected systems not have their
own power switches? If not, then you're
not really adding an avionics master but
simply a power control switch to a device
that does not already have one. In such cases,
it seems prudent to have a separate switch
for each device . . . this gets
around the issue of generating single points
of failure for multiple appliances.
Cost of ownership for adding switches will
be lower than for adding more batteries
that need to be maintained throughout
the life of the aircraft . . . but only
serve a useful purpose for a few tens of
milliseconds every flight cycle.
donjohnston
Posted: Tue Dec 06, 2016 10:38 am Post subject: Re: Avionics Master |
| nuckolls.bob(at)aeroelect wrote: | At 07:47 AM 12/6/2016, you wrote:
Do these affected systems not have their own power switches? |
Nope. These devices have no external controls.
| Quote: | | If not, then you're not really adding an avionics master but simply a power control switch to a device that does not already have one. In such cases, it seems prudent to have a separate switch for each device . . . this gets around the issue of generating single points of failure for multiple appliances. |
I thought about doing that. But I felt the additional wiring and switches to be an added complication. Besides, each device can be powered on or off through the VPX so that is my "individual device" switch. And my "Avionics Master" switch can be bypassed from the VPX as well (should it fail).
So to me, that seems like a win-win.
cluros(at)gmail.com Guest
Posted: Tue Dec 06, 2016 10:54 am Post subject: Avionics Master |
All the Beech products I flew had a NC relay opened by turning the avionics master switch off. If the switch failed and the avionics went dark, you just pulled the breaker for the switch and the avionics came back on.
Seems like a simple solution to me.
Sebastien
| Quote: | On Dec 6, 2016, at 10:38, donjohnston <don(at)velocity-xl.com> wrote:
http://forums.matronics.com/viewtopic.php?p=463754#463754
