art(at)zemon.name Guest
Posted: Mon Nov 28, 2016 7:50 pm Post subject: Problems Soldering DB-25 Connectors |
I found your explanation about the ballasting 22 AWG pigtails. It was in an email to me, not on your website. I will use this to update my blog post.
-- Art Z.
On Thu, Sep 22, 2016 at 9:01 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 08:22 PM 9/21/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Be careful about dry joints, the solder should be bright and shiny all around
the joint. |
. . . which is easy to achieve with 63/37 solder featuring
quality flux.
| Quote: | If the wire is carrying just signal, clipping a strand or two should
be fine . . . |
I've attached 18 AWG wires to solder-cups by trimming
back excess strands. This was a system with long runs
of wire where voltage drop was an issue. There are
companies that make special adapters to put too-large
wires into 20AWG solder-cups but trimming the strands
is more compact and works good too.
| Quote: | | (with adequate strain relief). |
The backshell is were wire-support takes place.
Heat shrink is more of a hedge against pin-to-pin
shorts by conductive contaminants . . . a thing
that just doesn't happen in a clean work environment.
| Quote: | Power carrying wire demand more careful consideration
about potential resistive heating and voltage drop. |
Sort of . . . but pin-to-socket interface within
the connector is the driving concern about path
resistance. 20AWG wire is 10 milliohms per FOOT,
22AWG is 16 mOhms/Ft. A single pin-to-socket
interface on a d-sub can present 3 millioms of
resistance over a millimeter. Variability in
resistance between pin-to-socket interface within
a connector gives rise to the prohibition for
paralleling pins to increase current handling
of any one path.
I designed and qualified a paralleled d-sub pin
process at Beech that was used in both targets
and production aircraft. This involved EXTENDING
each pin in a paralleled array with say 12" of
22AWG wire before the pin-paths were joined in
parallel. This ADDS 16 milliohms resistance to
each 1-3 milliohm pin-to-socket variability.
This 'ballasting' resistance forces the sharing
of current across an array of paralleled pins.
The short answer is that concerns for heating
due to current flow reside in the pins . . .
not the wires.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
Posted: Tue Nov 29, 2016 8:50 am Post subject: Problems Soldering DB-25 Connectors |
At 09:45 PM 11/28/2016, you wrote:
| Quote: | Bob,
I found your explanation about the ballasting 22 AWG pigtails. It was in an email to me, not on your website. I will use this to update my blog post. |
Oops . . . my bad. I'll update my own
postings as well. Thanks!
Posted: Mon Dec 05, 2016 9:36 am Post subject: Problems Soldering DB-25 Connectors |
At 10:48 AM 11/29/2016, you wrote:
| Quote: | At 09:45 PM 11/28/2016, you wrote:
| Quote: | Bob,
postings as well. Thanks! |
It took a little bit but I've uploaded the
paralleled d-sub pins saga at
http://tinyurl.com/jx96vpd
. . .even got it indexed. Man! I need to
spend more time on the website. There's about
a dozen updates I need to post. Anybody got some
36 hour days for sale?
