n5pb(at)AOL.COM Guest
				 Posted: Fri Jan 13, 2017 10:07 am    Post subject: Flickering on PCA9685 PWM controller with 3W  RGB LED |
				Chuoi,
   I do know too much about electronics, but a good friend of mine is an electrical engineer.  I asked him if he had any ideas to help you.  Here's what he said:
   Tell him.
   The way this works is to get the LED to "dim" your turning it on for 50 % of the time.  Real dim= the LED is on for 25% of the time.  What I think is happening is the 200 hz is too low for the DIM mode without flicker.  Try 1000 hz.  Using a cap on the LED side is a bad idea but it might help (prob not) on the 12V side.  Also get a VHF handheld and scan the comm band for noise when you are running this.  It is possible for these PWM switches to put out a lot of noise if not properly designed.  You don't want to be dimming the lights to find out you got no comm receiver anymore!
        Mike Dwyer
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
