		jetguy(at)att.net Guest
				 Posted: Tue Jan 17, 2017 4:21 pm    Post subject: RotaxEngines-List Digest: 4 Msgs - 01/16/17 |
				Test
     On Tuesday, January 17, 2017 2:15 AM, RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com> wrote:
 Today's complete RotaxEngines-List Digest can also be found in either of the
 two Web Links listed below.  The .html file includes the Digest formatted
 and Message Navigation.  The .txt file includes the plain ASCII version
 of the RotaxEngines-List Digest and can be viewed with a generic text editor
 HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-01-16&Archive=RotaxEngines
 Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-01-16&Archive=RotaxEngines
                            RotaxEngines-List Digest Archive
                      Total Messages Posted Mon 01/16/17: 4
 Today's Message Index:
      1. 05:41 AM - Re: Rotax Cylinder Head temperature gauge  (Roger Lee)
      2. 05:49 AM - Re: Coolant Hose  (Roger Lee)
      3. 06:32 AM - Re: Re: Coolant Hose  (Max Free)
      4. 11:06 AM - Re: Coolant Hose  (Roger Lee)
 ________________________________  Message 1  _____________________________________
 Time: 05:41:49 AM PST US
 Subject: RotaxEngines-List: Re: Rotax Cylinder Head temperature gauge
 From: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
 I'm with Jetguy. Try them and see what they read.
 Roger Lee
 Tucson, Az.
 Rotax Instructor & Rotax IRC
 Light Sport Repairman
 Home 520-574-1080  TRY HOME FIRST
 Cell 520-349-7056
 http://forums.matronics.com/viewtopic.php?p=465133#465133
 ________________________________  Message 2  _____________________________________
 Time: 05:49:08 AM PST US
 Subject: Re: Coolant Hose
 99% of the Rotax engines don't use silicone coolant hoses and they have run just
 fine since 1990. Just use a good grade of 1" coolant hose. If the hose is not
 at least 2" away from and exhaust pipe put some heat shield on that area. Hoses
 like Gates Green Stripe are 4 ply.
 Silicone hoses won't hurt, but aren't necessary.
 You are supposed to be changing hoses every 5 years along with other rubber parts.
 Not doing this is a roll of the dice. I think you just found out that isn't
 worth it.
 If this was an issue the entire Rotax engine users around the world would be busting
 hoses.
 Roger Lee
 Tucson, Az.
 Cell 520-349-7056
 http://forums.matronics.com/viewtopic.php?p=465135#465135
 ________________________________  Message 3  _____________________________________
 Time: 06:32:46 AM PST US
 From: "Max Free" <mcointe(at)free.fr (mcointe(at)free.fr)>
 Subject: RE: Re: Coolant Hose
  	  | Quote: | 	 		   99% of the Rotax engines don't use silicone coolant hoses and they have
 run just fine since 1990.
 So true ! but
  	  | Quote: | 	 		   You are supposed to be changing hoses every 5 years along with other
 rubber parts. Not doing this is a roll of the dice. I think you just found
 out that isn't worth it.
 Silicone hoses don't have time limits so you can avoid to change them
 according to legal authorities...
 Cordialement
 Max  Cointe
 F-PLDJ DynAro MCR 4S
 Kit #27-2002 1850 heures 912ULSFR/e-Props D100M
 -----Message d'origine-----
 De: owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)
 [mailto:owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] De la part de Roger
 Lee
 Envoy: lundi 16 janvier 2017 14:49
 : rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
 Objet: RotaxEngines-List: Re: Coolant Hose
 just fine since 1990. Just use a good grade of 1" coolant hose. If the hose
 is not at least 2" away from and exhaust pipe put some heat shield on that
 area. Hoses like Gates Green Stripe are 4 ply.
 parts. Not doing this is a roll of the dice. I think you just found out that
 isn't worth it.
 busting hoses.
 Roger Lee
 Tucson, Az.
 Cell 520-349-7056
 ________________________________  Message 4  _____________________________________
 Time: 11:06:40 AM PST US
 But you still have fuel, oil and the 17mm coolant hoses which there is no good
 US equivalent. You have carb rubber sockets, engine mounts, carb diaphragm, carb
 balance tube rubber.
 As an example real Teflon hoses for an RV12 fuel system will run $550 (approximately).
 Those still have to go into fire sleeve and so would oil hoses. Most of
 the time leaks and cracking show up at the clamped area and not mid hose unless
 the hose is being rubbed or too close to an exhaust pipe. How do you inspect
 hose under fire sleeve and under a clamp?
 For $550 I can buy all my hoses a couple times over and that would take care of
 me for 10-15 years.
 Flying safe and with some peace of mind is worth your time. If you can't afford
 to keep a plane's maint. up then flying may not be the best hobby for you. Throwing
 any old piece of hose you can on the engine and clamping it in place may
 make you a hazard waiting to hurt you and your passenger not to mention the
 high cost of any repair.
 Ask Huge what all this is going to cost by the time he's done?
 Roger Lee
 Tucson, Az.
 Cell 520-349-7056
 http://forums.matronics.com/viewtopic.php?p=465141#465141
  http://forums.matronhttp://wiki.matron                     -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
