		flysrv10(at)gmail.com Guest
				 Posted: Fri Feb 24, 2017 8:08 am    Post subject: Break model. |
				Guys,
 Need help.  Break failure at run up area. Need the wheel and caliper model to get o ring and pads.  Thanks a bunch.
		Tim Olson
				 Posted: Fri Feb 24, 2017 8:29 am    Post subject: Break model. |
				Hi Rob,
 If you are using stock Cleveland, then this is it:
 Brake Assembly 30-59E
 Brake Pads  66-112
 Rivets 105-2
 Disc part number RA164-07500 For Rapco version
 Wheel Assembly is 40-59A
 For caliper o-rings if you can go Viton, do it:
 The Viton o-rings are M83248/1-224  V-75
 Hope that helps you out!
 On 2/24/2017 10:07 AM, Rob Kermanj wrote:
  Guys,
		bdgillespie215(at)gmail.c Guest
				 Posted: Fri Feb 24, 2017 8:30 am    Post subject: Break model. |
				Not sure if this is what you are looking for.... had this noted in my POH.
 Main Brakes: 30-59E assy Torque 75-80 in-lb dry  Linings: Cleveland 66-112  Rivets: 105-2   Disc: 164-07500      Fluid: Aeroshell Mil-H-5606G
 Sent from my iPad
  	  | Quote: | 	 		   On Feb 24, 2017, at 11:07 AM, Rob Kermanj <flysrv10(at)gmail.com> wrote:
  Guys,
				 Posted: Fri Feb 24, 2017 8:52 am    Post subject: Break model. |
				Thank you! On my way to ABQ to pick up the parts.
  	  | Quote: | 	 		   On Feb 24, 2017, at 9:27 AM, Home <bdgillespie215(at)gmail.com> wrote:
  Sent from my iPad
 > Guys,
 > Sent from my iPhone
		gengrumpy
  Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
				 Posted: Fri Feb 24, 2017 9:01 am    Post subject: Break model. |
				Hope this helps!
 grumpy        Cleveland,   Wheel 40-59A; Disc 164-07500            Grease   seals: 153-00300 outer; 153-00400 inner. Snap ring 155-00100. Lining   066-11200. Rivet 105-00200. Dust Sheld 157-00900; Wheel bolts AN5-34A;   MS21044-N5 nuts                  Timken   Bearing LM274949-2-629, cotter pin AN 380-3-8. Torque halves 150in lb dry         	  | Quote: | 	 		  On Feb 24, 2017, at 10:52 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
 --> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> Thank you! On my way to ABQ to pick up the parts. Sent from my iPhone 	  | Quote: | 	 		  On Feb 24, 2017, at 9:27 AM, Home <bdgillespie215(at)gmail.com (bdgillespie215(at)gmail.com)> wrote:--> RV10-List message posted by: Home <bdgillespie215(at)gmail.com (bdgillespie215(at)gmail.com)>Not sure if this is what you are looking for.... had this noted in my POH.Main Brakes: 30-59E assy Torque 75-80 in-lb dry  Linings: Cleveland 66-112  Rivets: 105-2   Disc: 164-07500      Fluid: Aeroshell Mil-H-5606GSent from my iPad 	  | Quote: | 	 		  | On Feb 24, 2017, at 11:07 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:--> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>Guys,Need help.  Break failure at run up area. Need the wheel and caliper model to get o ring and pads.  Thanks a bunch. Sent from my iPhone |
  | 	  http://www.matronics.com/Navigator?RV10-Listhttp://wiki.matronics.com
		rv10flyer
				 Posted: Sat Feb 25, 2017 7:06 am    Post subject: Re: Break model. |
				I'd like to upgrade to Matco someday, as Van's chose a marginally sized brake system.
  _________________ Wayne G. |
