JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Fri Mar 24, 2017 11:56 am Post subject: Com antenna |
Hi Guys (Bob)
I've gone for the simple rod com antenna (http://www.aircraftspruce.com/catalog/avpages/stainlessantenna.php) having heard good reports (compared to the much more Comant types) the connection is a simple bolt - I presume PIDG connectors (both centre core and shield) keep them as short as possible, any other thoughts guys ?
Also: one more time - how close/distance from the transponder aerial should the two be ?
John RV9a
Posted: Fri Mar 24, 2017 12:31 pm Post subject: Com antenna |
At 02:56 PM 3/24/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
Hi Guys (Bob)
I've gone for the simple rod com antenna ( http://www.aircraftspruce.com/catalog/avpages/stainlessantenna.php) having heard good reports (compared to the much more Comant types) the connection is a simple bolt - I presume PIDG connectors (both centre core and shield) keep them as short as possible, any other thoughts guys ? |
That will work. Cessna produced thousands
of airplanes with that 'style' vhf comm
antenna. Is this a metal airplane? If
not, don't forget the radials.
| Quote: | | Also: one more time - how close/distance from the transponder aerial should the two be ? |
As far as practical . . . but I've seen
installations as short as 12" apart
where owners reported no observable
effects.
JOHN TIPTON
Posted: Fri Mar 24, 2017 12:48 pm Post subject: Com antenna |
Hi Bob
It's a Van's RV9a (all metal), so a decent mounting backing/plate will suffice - yes
----x--O--x----
On 24 Mar 2017, at 08:29 pm, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 02:56 PM 3/24/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
Hi Guys (Bob)
I've gone for the simple rod com antenna ( http://www.aircraftspruce.com/catalog/avpages/stainlessantenna.php) having heard good reports (compared to the much more expensive Comant types) the connection is a simple bolt - I presume PIDG connectors (both centre core and shield) keep them as short as possible, any other thoughts guys ? |
effects.
