graeme.hart(at)onecoolkat Guest
Posted: Fri May 12, 2017 4:22 am Post subject: Fwd: RE: Tail Plane Fitting |
| Quote: | Grear tip Gavin. The pins are probably 1/4 inch but I will measure tomorrow and then try to find a supply of imperial sized pipe in NZ, failing that I will have to place an Aircraft Spruce order.
On 12/05/2017 2:02 PM, "Gavin and Anne Lee" <gavanne(at)iconz.co.nz (gavanne(at)iconz.co.nz)> wrote: | Quote: |
Hi Graeme, yes definitely no hammer needed, if you slide a piece of metal tube of the same internal diameter over the pin you will soon see if it is aligned correctly with the torque tube and using the tube it will be easy enough to bend the pin into alignment
Gavin
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Graeme Hart
Sent: Wednesday, 10 May 2017 8:46 PM
Subject: Re: Tail Plane Fitting
Thanks Tim. It is good to know that the fitting should be snug with a little force, now I know what to aim for.
After sending the email I had a close look at the pins and I think one of them was slightly out of parallel with the torque tube. I've adjusted the pin slightly (yes, with a hammer and I'll reassemble later tonight and see how it goes.
Graeme
On Wed, May 10, 2017 at 8:31 PM, Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
--> Europa-List message posted by: Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
Hi Graeme,
They should be a snug fit, but certainly no hammer needed; should be easy to connect and disconnect with a little force.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob [url=tel:%2B64%20210640221]+64 210640221[/url]
| Quote: | On 10/05/2017, at 1:49 PM, Graeme Hart <graeme.hart(at)onecoolkat.com (graeme.hart(at)onecoolkat.com)> wrote:
Hi All
I'm working on fitting the tailplanes to the torque tube (chapter 18 in the build manual).
My starboard tailplane fits on reasonably easily but the port tailplane will only fully engage if I "assist" it in to place with a hammer. Removing the tailplane them becomes a 15 minute exercise involving gentle prying. This does not seem right to me.
I'm going to check the alignment of the TP12 drive pins with the torque tube as I suspect the pins may not be as parallel to the tube as they need to be.
I assume I should be able to attach and remove the tailplanes without the use of any tools.
I have attached a photo of the offending assembly in case it is not clear what parts I'm talking about.
I'd like to know how "snugly" should the tailplane fit on the torque tube from those who have made it past this point in construction.
Graeme (NZ)
| Quote: | <20170510_125136r.jpg>
