		Rebel56
				 Posted: Mon May 15, 2017 2:24 pm    Post subject: Radio static when using 12 volt lighter power plug |
				Obviously I have not grounded something properly, but I am at a loss.
 I have two cigarette lighter plugs wired into my aircraft. They are to provide power to my iPad on longer flights. I have noticed that whenever I have the iPad plugged in I get some static when I receive a transmission. Otherwise the radio is quiet. Not sure what to make of this. Why is it only on receiving? I would think that if it was a ground issue, I would have the static all the time.
 If there is nothing plugged into the power plug, I have no issues at all.
 Any ideas as to what I should check first.
 Rebel56
  |  | - The Matronics Avionics-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Avionics-List |
		fherr(at)cfl.rr.com Guest
				 Posted: Mon May 15, 2017 3:12 pm    Post subject: Radio static when using 12 volt lighter power plug |
				I suggest you check your battery first (age, charge level, capability to take a charge). You could be pushing it over the limit and may not hear any issue when transmitting.
 Easy checks that could solve the issue.
 Francis
 Rebel56
 http://forums.matronics.com/viewtopic.php?p=469331#469331
		swperk
				 Posted: Mon May 15, 2017 3:25 pm    Post subject: Re: Radio static when using 12 volt lighter power plug |
				Can you manually open the squelch on your receiver? If so, is the noise present when there is no transmission being received? If so, I suspect that the adapter that powers your iPad is emitting lots of RF noise and it's time to find a better one. I had the same problem with my plane, but mine was so bad that it was noisy enough to break the squelch on its own.
		gi(at)av8r.de Guest
				 Posted: Mon May 15, 2017 8:46 pm    Post subject: Radio static when using 12 volt lighter power plug |
				unfortunately there are a lot of those cheap USB power adapters for lighter plugs on the market. A lot of them are producing RF interference. I have had the same problems. You have to try a few until you find one that is not causing RF interference.
 Am 16.05.2017 um 00:24 schrieb Rebel56 <Rebel56(at)rogers.com>:
 Rebel56
