Pitot and static lines
mike(at)vision499.com
PostPosted: Tue May 30, 2017 3:54 pm    Post subject: Pitot and static lines Reply with quote
Is there a convention for color coding pitot and static lines to separate them visually?
jarra29(at)gmail.com
PostPosted: Wed May 31, 2017 8:22 am    Post subject: Pitot and static lines Reply with quote
RED - PITOTBLUE - STATIC
Hernán Antonio Padilla F.Técnico de Aviación La Ceiba, Atlántida. HondurasCel: (504) 3237-7799
El 30 may. 2017, a las 17:52, Mike Pienaar <mike(at)vision499.com (mike(at)vision499.com)> escribió:
--> KIS-List message posted by: "Mike Pienaar" <mike(at)vision499.com (mike(at)vision499.com)>Is there a convention for color coding pitot and static lines to separate them visually?ThanksMikehttp://www.matronics.com/Navigator?KIS-Listhttp://wiki.matronics.com
galinhdz(at)gmail.com
PostPosted: Mon Jun 05, 2017 10:35 am    Post subject: Pitot and static lines Reply with quote
FWIW most builders use:
White - Static
Green - Pitot
Blue - AOA
As seen in the attached drawing.  I did the same.
On Tuesday, May 30, 2017, Mike Pienaar <mike(at)vision499.com (mike(at)vision499.com)> wrote:
--> KIS-List message posted by: "Mike Pienaar" <[url=javascript:;]mike(at)vision499.com[/url]>
List" target="_blank">http://www.matronics.com/Navigator?KIS-List
lank">http://wiki.matronics.com
 Filesize:  170.05 KB
 Viewed:  5248 Time(s)
