Posted: Wed Aug 23, 2017 10:45 am Post subject: [Non-DoD Source] Re: Re: gear retraction problem |
This was a good way to hurt yourself, and your friends, and to impose stress loads in places that were never designed for same.
This was ignoring every bit of advice from every expert on this list that took the time to answer.
This was not making lemonade. This was careless and reckless.
Good Day.
Mark Bitterlich
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Thu Aug 24, 2017 7:08 am Post subject: [Non-DoD Source] Re: Re: gear retraction problem |
This judgment is a little rude MarkWhen we find a problem we try to solve it the best as we can. It happens that we make small or big mistakes but it is rude to say "careless and reckless"
Anyway nobody was hurt apparently thanks god and in the future I'm sure Bruno will read more patiently and carrefully the good (or less good!!!) advices of the list.
Thanks to all for your patient help care and support to us ignorant little pilots.
Didier
2017-08-23 20:44 GMT+02:00 Bitterlich, Mark G CIV NAVAIR, WD <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Good Day.
Mark Bitterlich
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
Posted: Thu Aug 24, 2017 9:19 am Post subject: [Non-DoD Source] Re: Re: gear retraction problem |
Ok Didier..... since you brought it up.....
Let me be perfectly clear. Aircraft Maintenance has been my profession for over 40 years. How many others reading this email can say that? So let me be specific and hopefully educational. And saying this, I expect negative feedback by the usual folks who demand political correctness at every step.
This gentleman was correctly advised by a number of experts to use proper equipment, namely proper aircraft jacks, in order to cycle the landing gear. In fact one person actually begged him to do that, because he was worried the gent might try to make up some method using whatever he had at hand, without any experience and/or prior knowledge. All good advice. This gent then ignored that advice.
1. The engine mount is not designed or stressed to be used as a lifting point for raising the aircraft. However, it was used for that function in this lift. Just because something does not snap and break when you put stress on it, does not mean it has not been damaged. So now there is the possibility of unknown damage to a critical piece of hardware. Not LIKELY, but entirely possible.
2. The aircraft was lifted using the actual structure of the building as a method to support the weight. There were no load tests or engineering reviews done on the structural condition of the hangar roof, as was pointed out by someone else on this list. The hangar roof is not something that is designed to be load bearing even if made from steel. What kind of prior load tests were done using this method? Any?
3. Straps and come-a-longs were used to attach to non-specified and non-tested lift points. Once again to get the aircraft off the ground.
4. Once off the ground, people climbed on the aircraft, and actuated the landing gear. Had anything failed at this point, there is a strong chance people would have been hurt.
The fact is that in aircraft maintenance, the end never justifies the means. This gent got away with this ad-hoc method once. I am glad he did. I do not wish loss or injury to anyone and I am sure no one else does either.
But ask yourself this question: If any official of any aviation agency from any country in the world saw this being done, what would they have called it and what would they have done about it? In the United States, the aircraft owner is actually ultimately accountable for work being performed on his aircraft. Yes, there are many "but if's" to this statement, but ultimately it can come down to that. Had anything failed in this effort, had anyone gotten hurt, what would the judgement have been by the FAA?
Were the manufacture's procedures followed when performing this work?
NO.
Was proper equipment being used that had been properly load tested as called for in the procedures?
NO.
Did the owner use a totally unauthorized procedure which put the aircraft, himself and those around him at risk?
YES.,
All of this adds up to, and meets the definition of being "careless and reckless". What makes it worse is that this gentleman asked about doing it first to everyone on this list, was strongly advised not to, and then did it anyway. After doing it, he seemed to feel pretty good about it, taking pictures and advising others how to go about doing it. Going further still, one reader actually classified his actions in a congratulatory sense, which of course encourages others to ignore every bit of regulatory process and do whatever they feel is necessary to get the results they are looking for as well. That kind of attitude is DANGEROUS.
At the end of the day, this gent has YET to follow the exact troubleshooting steps recommended by the foremost expert on this system found on this list-server. Which means this aircraft is going to have to go back up into the air again, and unless someone speaks up and says DO NOT DO THIS! I did. In no uncertain terms. My conscience is clear.
Over the years I have spent helping others on the Yak List, I have learned to recognize those that only use advice to get what they want, and ignore every caution offered in the process. Thus I am now much more cautious giving it these days as it comes with a sense of responsibility.
So Didier, my choice of words might be considered "rude" by some I fully admit. But they are 100% accurate.
Mark
Looigi
Joined: 20 Apr 2015 Posts: 81 Location: Christchurch, New Zealand
Posted: Thu Aug 24, 2017 9:57 am Post subject: Re: [Non-DoD Source] Re: Re: gear retraction problem |
I have been trying very hard to stay out of this debate, but I can't let the "Nobody died so it was ok" suggestion go without comment. Mark is 100% correct with his comments.
Like Mark, I have been fixing airplanes for a long time now, mostly in the military and airline worlds. Like Mark I am of the opinion that this is a very good demonstration of how not to jack an aeroplane.
The "Battle conditions, the enemy is coming" attitude is fine, when they actually are. In this case, they weren't, and the risks taken here far outweigh the cost of a few bottles of beer it would have probably taken to borrow a set of suitable jacks.
I am about to make a set of jacks for my own Yak-52, and I am guessing that a set of four jacks will cost me less than $500 NZ and a day with the welder.
Bruno, give me a few weeks to clear some other jobs out of my life and I will post some pictures of them and a drawing..... Go and get some made. Please.
Chris
j.mevis(at)computer.org Guest
Posted: Thu Aug 24, 2017 10:07 am Post subject: [Non-DoD Source] Re: Re: gear retraction problem |
Didier, I concur with this point of view of Mark.
I was horrified when I saw the pictures with the Nanchang hanging at the
wooden roof of a hangar.
A friend of mine is a military constructions engineer.
I showed him the pictures. He was amazed too (understatement).
Anyway, I hope that your friend will get the problem solved and I wish him
many safe flights.
BR,
Jan
On 24/08/2017, 19:18, "Bitterlich, Mark G CIV NAVAIR, WD"
<owner-yak-list-server(at)matronics.com on behalf of
mark.bitterlich(at)navy.mil> wrote:
<mark.bitterlich(at)navy.mil>
does either.
been by the FAA?
NO.
NO.
YES.,
DANGEROUS.
Mark
pa3arw(at)ziggo.nl Guest
Posted: Thu Aug 24, 2017 10:24 am Post subject: [Non-DoD Source] Re: Re: gear retraction problem |
And that's the way it is! I totally agree!
Amen!
Hans Oortman
PH-YAK
Op 24-08-17 19:18, Bitterlich, Mark G CIV NAVAIR, WD
possible.
NO.
NO.
YES.,
Mark
dabear
Joined: 21 Jan 2011 Posts: 92 Location: Warrenton, VA
Posted: Mon Aug 28, 2017 6:23 am Post subject: [Non-DoD Source] Re: Re: gear retraction problem |
Once again Mark brings reason, experience, knowledge to the discussion.
They were lucky the airplane didn't come down on someone or that the
whole hangar didn't come down on them.
NO.
NO.
YES.,
Mark
