jpoint(at)wi.rr.com Guest
Posted: Tue Sep 05, 2017 6:57 pm Post subject: Troubleshooting 200G/ Z-17 |
All,
Just closing the loop on this discussion- after talking with both B&C
and Earth-X about this, I began to realize that what I was seeing was
normal behavior for this type of setup. I made the first flight of the
aircraft a couple weeks ago and now have about five hours of flight data
(engine monitor data) to look at. The voltage does start out low but
once takeoff power is applied, the voltage slowly climbs to 14.55V over
about a minute and remains there for the duration of the flight.
I have informed both companies of the outcome. Both have been excellent
to deal with- particularly B&C who sent me a new regulator when it
initially appeared that it was defective.
Hopefully this will help someone else in the future.
Jeff Point
Milwaukee
On 7/11/17 10:04 PM, Jeff Point wrote:
Quote: |
All,
The good news from today is that I successfully ran my freshly
overhauled O-200 today in preparation for a FAA inspection in a few
weeks. The bad news is that I am getting no alternator output at
all. The alternator is a B&C 200G PM dynamo, wired per Z-17 (no
master contactor.) Running the engine between idle and 1800 RPM saw
no change in bus voltage, which stayed at the same 13.1V as it did
with the engine not running.
Troubleshooting so far- besides checking all wiring connections, I
verified that the OV relay is working and that I wired it correctly.
I verified that the alternator's raw output was as expected (15-25VAC,
increasing with speed.) I measured voltage at the capacitor (just
downstream of the regulator) and it was the same 13.1 and did not vary
with speed. Disconnecting the regulator I verified that there is zero
volts coming out of the regulator, although I understand from the
troubleshooting documents that it must have bus voltage applied in
order to output, so I'm thinking this doesn't mean much.
Is this as simple as a bad regulator? I'm going to call B & C first
thing tomorrow but I thought I'd check here first.
Jeff Point
Milwaukee
Posted: Wed Sep 06, 2017 10:02 am Post subject: Troubleshooting 200G/ Z-17 |
At 09:55 PM 9/5/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com>
All,
Just closing the loop on this discussion- after talking with both B&C and Earth-X about this, I began to realize that what I was seeing was normal behavior for this type of setup. I made the first flight of the aircraft a couple weeks ago and now have about five hours of flight data (engine monitor data) to look at. The voltage does start out low but once takeoff power is applied, the voltage slowly climbs to 14.55V over about a minute and remains there for the duration of the flight. |
Sorry I didn't pick up on that . . . the EarthX
battery is a much less compliant current sink
than a lead-acid . . . hence willing to take
on recharge currents that combine with your
system loads to depress alternator output until
the battery tops off.
I'm working on some new regulator control and
voltage monitoring philosophies for future
designs . . . designs that I hope will be
compatible with both lead-acid and lithium
technologies and I've noted the effects you're
seeing now. This will be limited to 'small'
alternators like the SD8 and 200G and to a lesser
degree with the built in PM alternators like
Rotax.
Posted: Wed Sep 06, 2017 4:59 pm Post subject: Troubleshooting 200G/ Z-17 |
No worries Bob and thanks. We're all still learning about this new LiFePo stuff.
Talking with Nathan B at Oshkosh he said he was working on a new regulator design for the PM alternators (might be what you're working on.) I offered to be a beta tester as I have a data recording engine monitor and could possibly gather some useful data. I have data from my last 5 hours that I can provide if you think it would be of any value. It's interesting to look at the voltage rise vs. RPM. There is even a slight rise during runup that I didn't notice while running up, but is clear from the data.
Jeff
On 9/6/17 1:02 PM, Robert L. Nuckolls, III wrote:
Quote: | At 09:55 PM 9/5/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com> (jpoint(at)wi.rr.com)
All,
Rotax.
Bob . . . |
Posted: Thu Sep 07, 2017 4:04 pm Post subject: Troubleshooting 200G/ Z-17 |
At 07:58 PM 9/6/2017, you wrote:
Quote: | No worries Bob and thanks. We're all still learning about this new LiFePo stuff.
Jeff |
Absolutely! Thank you. I'll have a bench-test
article that will not be mechanically pure to
the production drawings but electronically
identical and air worthy. I'd be pleased to
exploit your offer.
