		jpoint(at)wi.rr.com Guest
				 Posted: Tue Sep 05, 2017 6:57 pm    Post subject: Troubleshooting 200G/ Z-17 |
				All,
 Just closing the loop on this discussion- after talking with both B&C
 and Earth-X about this, I began to realize that what I was seeing was
 normal behavior for this type of setup.  I made the first flight of the
 aircraft a couple weeks ago and now have about five hours of flight data
 (engine monitor data) to look at.  The voltage does start out low but
 once takeoff power is applied, the voltage slowly climbs to 14.55V over
 about a minute and remains there for the duration of the flight.
 I have informed both companies of the outcome.  Both have been excellent
 to deal with- particularly B&C who sent me a new regulator when it
 initially appeared that it was defective.
 Hopefully this will help someone else in the future.
 Jeff Point
 Milwaukee
 On 7/11/17 10:04 PM, Jeff Point wrote:
  All,
  The good news from today is that I successfully ran my freshly
  overhauled O-200 today in preparation for a FAA inspection in a few
  weeks.  The bad news is that I am getting no alternator output at
  all.  The alternator is a B&C 200G PM dynamo, wired per Z-17 (no
  master contactor.)  Running the engine between idle and 1800 RPM saw
  no change in bus voltage, which stayed at the same 13.1V as it did
  with the engine not running.
  Troubleshooting so far- besides checking all wiring connections, I
  verified that the OV relay is working and that I wired it correctly.
  I verified that the alternator's raw output was as expected (15-25VAC,
  increasing with speed.)  I measured voltage at the capacitor (just
  downstream of the regulator) and it was the same 13.1 and did not vary
  with speed.  Disconnecting the regulator I verified that there is zero
  volts coming out of the regulator, although I understand from the
  troubleshooting documents that it must have bus voltage applied in
  order to output, so I'm thinking this doesn't mean much.
  Is this as simple as a bad regulator?  I'm going to call B & C first
  thing tomorrow but I thought I'd check here first.
  Jeff Point
  Milwaukee
				 Posted: Wed Sep 06, 2017 10:02 am    Post subject: Troubleshooting 200G/ Z-17 |
				At 09:55 PM 9/5/2017, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com>
  All,
  Just closing the loop on this discussion- after talking with both B&C and Earth-X about this, I began to realize that what I was seeing was normal behavior for this type of setup.  I made the first flight of the aircraft a couple weeks ago and now have about five hours of flight data (engine monitor data) to look at.  The voltage does start out low but once takeoff power is applied, the voltage slowly climbs to 14.55V over about a minute and remains there for the duration of the flight. |
    Sorry I didn't pick up on that . . . the EarthX
    battery is a much less compliant current sink
    than a lead-acid . . . hence willing to take
    on recharge currents that combine with your
    system loads to depress alternator output until
    the battery tops off.
    I'm working on some new regulator control and
    voltage monitoring philosophies for future
    designs . . . designs that I hope will be
    compatible with both lead-acid and lithium
    technologies and I've noted the effects you're
    seeing now. This will be limited to 'small'
    alternators like the SD8 and 200G and to a lesser
    degree with the built in PM alternators like
    Rotax.
				 Posted: Wed Sep 06, 2017 4:59 pm    Post subject: Troubleshooting 200G/ Z-17 |
				No worries Bob and thanks.  We're all still learning about this       new LiFePo stuff.
 Talking with Nathan B at Oshkosh he said he was working on a new       regulator design for the PM alternators (might be what you're       working on.)  I offered to be a beta tester as I have a data       recording engine monitor and could possibly gather some useful       data.  I have data from my last 5 hours that I can provide if you       think it would be of any value.  It's interesting to look at the       voltage rise vs. RPM.  There is even a slight rise during runup       that I didn't notice while running up, but is clear from the data.
 Jeff
      On 9/6/17 1:02 PM, Robert L. Nuckolls,       III wrote:
       	  | Quote: | 	 		         At 09:55 PM 9/5/2017, you wrote:
                	  | Quote: | 	 		  -->           AeroElectric-List message           posted by: Jeff Point <jpoint(at)wi.rr.com> (jpoint(at)wi.rr.com)
            All,
          Rotax.
              Bob . . .                 |
				 Posted: Thu Sep 07, 2017 4:04 pm    Post subject: Troubleshooting 200G/ Z-17 |
				At 07:58 PM 9/6/2017, you wrote:
   	  | Quote: | 	 		  No worries Bob and thanks.  We're all still learning about this new LiFePo stuff.
  Jeff |
    Absolutely! Thank you. I'll have a bench-test
    article that will not be mechanically pure to
    the production drawings but electronically
    identical and air worthy.  I'd be pleased to
    exploit your offer.
