JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Tue Nov 07, 2017 6:22 am Post subject: Fuse link |
Hi - My A/p control unit is placed on the left panel, the wire call-out is 22AWG with 5amp fuse or C/b, I'm going to put a C/b on the right panel, to serve as isolation or quick disconnect from co-pilot side, with the total run about 4 feet, C/b at mid point, do I up the wire to 18AWG, and put a 22AWG fuse link at the un-fused bus - regards: John
Posted: Tue Nov 07, 2017 9:58 am Post subject: Fuse link |
At 08:22 AM 11/7/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
Hi - My A/p control unit is placed on the left panel, the wire call-out is 22AWG with 5amp fuse or C/b, I'm going to put a C/b on the right panel, to serve as isolation or quick disconnect from co-pilot side, with the total run about 4 feet, C/b at mid point, do I up the wire to 18AWG, and put a 22AWG fuse link at the un-fused bus - regards: John |
The a/p control head doesn't have a power switch on it?
Don't understand the need for pressing breakers into
service as failure mitigation devices. What kind of a/p
are we talking about?
JOHN TIPTON
Posted: Tue Nov 07, 2017 4:27 pm Post subject: Fuse link |
As mentioned, the C/b was going to be there to isolate the A/p on the copilot side, the pilots stick has a servo disconnect button - the A/p is a Trio ez-pilot
----x--O--x----
On 7 Nov 2017, at 3:18 pm, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | At 08:22 AM 11/7/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
Posted: Tue Nov 07, 2017 6:15 pm Post subject: Fuse link |
At 06:24 PM 11/7/2017, you wrote:
Quote: | As mentioned, the C/b was going to be there to isolate the A/p on the copilot side, the pilots stick has a servo disconnect button - the A/p is a Trio ez-pilot
Not sure what 'isolate' means . . . is it your desire
to place an a/p disconnect feature in reach of the
copilot?
JOHN TIPTON
Posted: Wed Nov 08, 2017 12:51 am Post subject: Fuse link |
Hi Bob
Yes: the C/b
----x--O--x----
On 8 Nov 2017, at 2:14 am, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
copilot?
zwakie
Posted: Wed Nov 08, 2017 7:03 am Post subject: Re: Fuse link |
Hi John, I don't understand why you would want to use a c/b (in the power feed line?!?) of the Trio where it has a pin dedicated that disconnects the A/P when connected to ground.
I don't have the pin number readily available, but all you would need is a normally open momentary switch that you can wire in parallel to the switch you already have. Wire-size is not critical because of the NO characteristic of the switch...
_________________ Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR |
Posted: Wed Nov 08, 2017 7:30 am Post subject: Fuse link |
At 02:49 AM 11/8/2017, you wrote:
Quote: | Hi Bob
Yes: the C/b
John |
I sense that you are perhaps putting too
much weight on an a/p failure. First, the
the most likely failure is simple shut down
(quits and relaxes) or, if it uses stepper
motors, freezes up. The least likely failure
is a hard-over runaway.
Should a runaway occur, the first thing
you do is grab the stick and regain control.
The a/p is physically incapable of forces
you cannot manage manually. Once control is
achieved, getting it shut down is no big deal.
I would resist adding any more hardware or holes
in the panel just to effect a/p shutdown when
the event being managed is not an emergency.
JOHN TIPTON
Posted: Wed Nov 08, 2017 10:25 am Post subject: Fuse link |
Hi Marcel
Yes: I've got the servo disconnect available ready for the pilots stick grip, my thought is to put a breaker over on the right, so the copilot can have a 'disconnect' (that side will only have a PTT).
----x--O--x----
Marcel Zwakenberg
http://forums.matronics.com/viewtopic.php?p=474621#474621
JOHN TIPTON
Posted: Wed Nov 08, 2017 10:35 am Post subject: Fuse link |
Hi Bob
Yes, you have summed it all up, what has been in my mind.
22AWG wire, 5amp fuse on the fuse block - no C/b ---
Thank you
----x--O--x----
On 8 Nov 2017, at 3:30 pm, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | At 02:49 AM 11/8/2017, you wrote:
Quote: | Hi Bob
Yes: the C/b
John |
