Water cooler vs duct
alan.twigg775(at)gmail.co
PostPosted: Thu Jan 11, 2018 7:10 am    Post subject: Water cooler vs duct Reply with quote
I have a set of Nev’s cowlings, with revised radiator duct sides ( CD2&3), Nev acquired for me a radiator with extra jackets to the side and side exiting hoses.
I have installed it which involved cutouts in the side panels, this means mounting forward of the footwell. I now have not enough room between lower cowl and the radiator, Ie negative by 10mm.
Has anyone fitted this sort of radiator? I am close to ditching it and fitting the original standard, (does anyone have a spare?
Alan Twigg
Motorglider kit 463
Almost there, radiator and control set ups to go. 2018 might be the year.
JonathanMilbank
PostPosted: Thu Jan 11, 2018 1:52 pm    Post subject: Re: Water cooler vs duct Reply with quote
Hi Alan,
I too have installed Nev's cowlings and I took his advice to fit the same water radiator in the same position as found in the XS installation, but I also took his advice to use the oil cooler from my original Classic cowlings. No problems.
Perhaps you could attach a few photographs to enable better understanding of your set-up.
Jonathan
spcialeffects
PostPosted: Thu Jan 11, 2018 2:10 pm    Post subject: Re: Water cooler vs duct Reply with quote
Hi Alan. I too have fitted Nev’s cowls and have plenty of photos of my installation if your interested as a photo says a thousand words. My email is spcialeffects(at)aol.com
Regards Frank
Nigel Graham
PostPosted: Fri Jan 12, 2018 8:53 am    Post subject: Re: Water cooler vs duct Reply with quote
........"I am close to ditching it and fitting the original standard, (does anyone have a spare? "
I might be able to help you out Alan. Contact me off list.
Nigel
