Yak-List: Re: Yak-List: Removing CJ’s Emergency Air Tank
colin mcgeachy
PostPosted: Tue May 08, 2018 7:17 am    Post subject: Yak-List: Re: Yak-List: Removing CJ’s Emergency Air Tank Reply with quote
It's relatively straightforward. Pull the battery tray and, if memory serves, you'll need to remove one of the tray rails. There's not a lot of room but it will lift up and out once the pipework is disconnected.
Colin
On Tue, May 8, 2018, 11:03 AM Justin Drafts, <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Good morning Byron,
Have you heard any tips & techniques yet?
I'm curious myself, as I may be replacing my own E-bottle soon.
All I can immediately think of is going back thru the aft "wall" of rear cockpit and up thru the circular cutout in the belly aft of the E-bottle.
Justin Drafts
N280NC
On Sat, May 5, 2018 at 3:29 PM, Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
I intend remove and replace this tank which lies below the rack on which my batteries sit. I’m looking for any guidance from those who’ve undertaken this task.
Blitz Fox415-307-2405
Colin (C-FTGZ)
Clouddog
PostPosted: Tue May 08, 2018 7:21 am    Post subject: Yak-List: Re: Yak-List: Removing CJ’s Emergency Air Tank Reply with quote
Position the body of bottle so the Emergency Bottle drain is pointing down
through the lower bracket body. The tubing guess forward, under the radio
rack supports (cargo area) and to the right sure of aircraft. Then go
forward up the right side of aircraft to aft emergency handle, then forward
PostPosted: Tue May 08, 2018 8:01 am    Post subject: Yak-List: Re: Yak-List: Removing CJ’s Emergency Air Tank Reply with quote
Indeed I did, Justin.
Jon Blake wrote the he replaced his emergency tank in Februaryby removing “the sheet metal making up the floor of my baggage compartment. “
....Where your battery rack is installed there is a wider opening to remove the bottle vertically (up). No removal of the racks are required”
On May 8, 2018, at 7:52 AM, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Good morning Byron,
Justin Drafts
N280NC
