ceengland7(at)gmail.com Guest
Posted: Tue Nov 27, 2018 11:54 am Post subject: Need help with some Z-14 electrical system troubleshooting |
On 11/27/2018 1:04 PM, Bill Watson wrote:
<Mauledriver(at)nc.rr.com>
(the Z-14 has 2 buses, 2 alternators and 2 batteries - B&C alternators
and regulators, Odyssey batteries)
I regularly fly with the 2 buses not interconnected. At cruise I've
been seeing between 14.5 and 14.7 volts on both buses. I've been
running like that for over a year.
On my last flight I noticed the voltage on bus 2 dropped almost 1
volt. It was jumping around between 13.4 and 14.0 volts. I removed
various loads to see if perhaps I had a malfunctioning component but
this had no effect.
I engaged the cross feed to connect the 2 buses. Bus 2 remained at 14
volts or less but was less jumpy staying closer to 14. Bus 1 remained
at 14.5 to 14.7.
With the cross feed engaged and Bus 2 switched off, the voltage on Bus
2 dropped to between 12.4 and 13.7
With the cross feed engaged, I pulled the CB on the bus 2 regulator
taking the #2 regulator/alternator offline. Bus 2 voltage was between
12.8 and 13.5 (bus 1 was 14.5)
I don't have a load tester but the bus 2 battery seems okay
(12.78volts with no load at 50F). It would seem that I'm getting some
current from the alternator but there has been a distinct drop in bus
2 voltage. I would have thought that both buses would have roughly
the same voltage when interconnected with the bus 2 alternator offline.
I'm looking for some advice on troubleshooting. Thanks!
Any chance you have an instrument error issue? If you put a digital
meter on each bus, what does it say? If you verify low voltage, maybe a
shorted diode in the alternator?
yellowduckduo(at)gmail.co Guest
Posted: Tue Nov 27, 2018 11:57 am Post subject: Need help with some Z-14 electrical system troubleshooting |
Nice description. My Z14 does show both voltages the same with the
crossfeed closed as you surmise. I'd want to verify that the buss 2
voltage is accurate with a separate meter.
Next I'd physically disconnect the buss 2 alternator to see what
happens. Or measure the current from (or into) the #2 regulator or
alternator if you have a current meter. A DC Clamp ON ammeter is handy
for rough DC current measurements. (under $20. on ebay).
Ken
On 2018-11-27 2:04 p.m., Bill Watson wrote:
On my last flight I noticed the voltage on bus 2 dropped almost 1 volt.
It was jumping around between 13.4 and 14.0 volts. I removed various
loads to see if perhaps I had a malfunctioning component but this had no
effect.
at 14.5 to 14.7.
With the cross feed engaged and Bus 2 switched off, the voltage on Bus 2
I don't have a load tester but the bus 2 battery seems okay (12.78volts
with no load at 50F). It would seem that I'm getting some current from
the alternator but there has been a distinct drop in bus 2 voltage. I
would have thought that both buses would have roughly the same voltage
