Rotax 912ULS/S - suggested "health" warning
JonathanMilbank
PostPosted: Fri Mar 01, 2019 3:43 am    Post subject: Rotax 912ULS/S - suggested "health" warning Reply with quote
To avoid psychological distress and the unnecessary expensive inconvenience of having to remove your Rotax 912ULS/S engine in order to change the starter sprag clutch prematurely, replace your aircraft's battery at intervals no greater than 2 years. Ensure that the battery is fully charged before any start attempt. This advice is particularly pertinent to engines fitted with the heavier propeller hubs, such as the excellent Airmaster.
Please see: http://forums.matronics.com/viewtopic.php?p=487875#487875
