docclv(at)windstream.net Guest
Posted: Sat Mar 14, 2020 5:46 am Post subject: RV10 Stick pulsations |
Have 2 RV10s with 500+ hours between the 2. We have not noticed any
pulsations in the stick even at Max Air Speed. We fitted the counter
balance aileron weights tightly in the aileron horns when built assuming
the aileron needed all the counter balance weight it could get. We also
fitted the aileron tips to 1/16 in clearance. I would make sure your
elevator trim tabs are properly set. Would also recommend talking to
Vans. Elevator flutter (stress) has lead to cracking a bulk head in the
tail on earlier serial numbers leading to an SD (see Vans SD List).
#41087 & 41862. Doc
