bobbypaulk(at)comcast.net Guest
Posted: Tue Mar 24, 2020 10:20 am Post subject: Fwd: engine |
Subject: engine
John
I added a 40 amp alternator and got rid of the original charging apparatus. My battery would almost be fully charged when I got back to my hangar. I also installed a electronic ignition on the left side and changed the right ignition coil for a later model hotter Honda generator coil ( part no. 30500-Z1C-023 ). When hot I start the engine with the right mag on and wait until one revolution before turning on the electronic ignition because it does not have a retard method. The engine is always running before I can flip the switch on for the electronic ignition. I had to change carburetor jets for nearly a year until I got a usable set. I then found out that Jabiru had found out the same ones but I had not heard. I still have some leaner RPM's than I would like between 2500 and 2750.
johndread(at)AOL.COM Guest
Posted: Tue Mar 24, 2020 4:16 pm Post subject: Fwd: engine |
Hi Bobby,
Thanks for the note. Very helpful.
John Read
Windyridge Consulting
Phone 303.648.3261
Mobile 719.494.4567
In a message dated 3/24/2020 2:16:55 PM Mountain Standard Time, bobbypaulk(at)comcast.net writes:
Subject: engine
John
