albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Tue Dec 29, 2020 6:36 am Post subject: Conventional tailwheel prop clearance |
Hi,
For the conventional tailwheel operators, did you gain any prop clearance from the monowheel setup?
Tony
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
Duncan McFadyean
Posted: Tue Dec 29, 2020 7:56 am Post subject: Conventional tailwheel prop clearance |
Some did, some didn't.
The Swiss gearleg gives a lot more clearance than the mono. But some of those fitted were cut down (!) to provide the same ride height as the mono.
Duncan McF. | Quote: | On 29 December 2020 at 14:35 Tony Braun <albertaflyer(at)gmail.com> wrote:
Hi,
Tony
DuaneFamly(at)aol.com Guest
Posted: Tue Dec 29, 2020 11:31 am Post subject: Conventional tailwheel prop clearance |
Tony, prop clearance depends on both which prop was installed and which conventional gear was installed.
Mike Duane N377EA
Chandler, AZ
| Quote: | On Dec 29, 2020, at 7:36 AM, Tony Braun <albertaflyer(at)gmail.com> wrote:
Hi,
Tony
