MJKTuck(at)cs.com Guest
Posted: Sat Feb 06, 2021 1:07 pm Post subject: Rotax 912ULS starter motor |
Hi all,
Closer scrutiny of the SkyTec starter shows eligibility for the Rotax 912ULS Serials 4425001 and on.
I have an older 912UL. Do you know if there a similar hi-torque starter available for it?
Anyone have experience installing the SkyTec starter on the 912UL?
Martin Tuck
On 12/3/2020 6:47 AM, Bud Yerly wrote:
| Quote: | (at)font-face {font-family:Helvetica; panose-1:2 11 5 4 2 2 2 2 2 4;}(at)font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;}(at)font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;}p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0in; font-size:11.0pt; font-family:"Calibri",sans-serif;}a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;}.MsoChpDefault {mso-style-type:export-only;}div.WordSection1 {page:WordSection1;}
Martin,
Remember all the posts, SBs, SLs, Sis on �Genuine Rotax Parts� kept coming on and on?
I normally use Rotax parts on my engine because I can afford it and I plan on selling my aircraft when I get old.�� My plane and I are aging similarly by the way.� But my plane is easier to touch up and is not growing hair out of its ears.
The Sky-tec has the same nose seal as the Rotax.� The problem with �Joe Bag of Doughnuts� installer is they fail to note the spacers and O rings that go on the spindly threaded rods.� Sky-tec threaded rods are not as hard a steel as the Rotax and bend usually in shipment.� I�ve had to straighten them and fab a new spacer to suit my liking to get the gear length exactly the length of the other starter, which was a waste of time.� Simply reinstall the existing spacers and the clamp and it works just fine.
The Rotax heavy MX manual shows the spacers, O rings and clamp.� That rear clamp will keep the starter securely fastened preventing the somewhat soft threaded rods from worrying you about a sagging starter.
You just have to work around the ring mount, footwell, and any hose/electrical routings with cold fingers getting it all back into place without pulling apart.� The O rings help but I find using safety wire to hold the starter nose and tail tight while installing prevents the starters from falling apart on install which can damage brushes.� Once the starter starts to slip in place, and you have not forgotten to put the clamp back on, simply cut the .020 safety wire off, and push it home.�
I normally do starter changes and engine rubber mount changes at the same time by pulling the engine on a 5 year.� If you make the engine easy to disconnect and come off like a pod, it is a 4 hour hose, rubber, starter cleanup, and service rather than days of frustration.
Best Regards,
Bud Yerly
Sent from Mail for Windows 10
Sent: Wednesday, December 2, 2020 11:09 PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Re: Rotax 912ULS starter motor
Nine years ago on the Rotax Owners Forum there was some commentary surrounding the suitability of the Sky-Tec starter due to the lack of oil seal resulting in oil in the starter and possibly compromising the oil return system.
This is explained in a Rotax service bulletin.
See Rotax Service Letter�SL-912-014 / 914-012 / 2ST-008�for more information.
That was a while ago and put me off the idea of using that starter.
Do you know if the Sky-Tec starter has since been modified to prevent this? It doesn't sound like those who have used it have had issues like this.
Martin Tuck
N152MT
Wichita, Kansas
On 12/1/2020 7:16 PM, Bud Yerly wrote:
Arwel,
In my Troubleshooting guide I mention the starter issues.
It is my opinion all Rotax engines should upgrade to the high torque starter.
I�ve tried them both.� The Rotax high torque is what I installed ($1100USD), mainly because my plane was kept stock as much as possible.� For the Experimenter I recommend the Sky-Tec as it costs half (<$500 USD) as much and is quite torquey.�
Both spin the prop with authority, easily surpasses the ignition excitation speed.� With plugs in and ignition off, I see 500 RPM for a 914/912 and 400-450 for a 912S/iS.�
Even with a slightly low battery, starts are crisp.� This lengthens the life of the sprag clutch.� But these clutches do wear and somewhere within 1000 hours even on a well maintained 912S engine with good starting, it may fail.
In my Rotax troubleshooting update in March, I went into the soft start/starting ignition problems of the Rotax.� As many have learned, once the starter can�t push past the compression peak at ignition, the engine will kick back which will quickly wear the sprag clutch.� What I didn�t explain completely was when the sprag clutch begins to weaken and slightly slip, this will exacerbate the kickback issues.� Adding a high torque starter on a defective clutch will not be the total answer to the kickback.� Because the Rotax sprag clutch is a trapped un-round roller type one way clutch, if the spring that holds the un-round roller in place is loaded excessively, the spring stretches which causes the clutch to slip so it no longer is an effective one way clutch.� The good news is there is no damage to the starter or the crank shaft when this happens unless the engine continues to have �kick backs� with the defective clutch, then things break and fowl the engine with metal parts. Which means it goes from a somewhat expensive repair to a very expensive repair. Youtube has videos on the different types of these one way clutches.
I recommend that if you have an XS firewall forward (with the ring mount) the high torque starter will fit.� (Note the Rotax high torque may come with the tabs still attached which must be cut/ground off.� Our dealers in the States supply them ready to install without the tabs.)� I found the Sky-Tek to be well built and spun up quickly on some light sport aircraft we have around here.� I think it is good insurance for preserving the sprag clutch. ��The Sky-Tek is cheaper also.
For those with the Classic FWF, I�m afraid neither of the high torque starter options will fit the original Classic mount.� It is too long by only a few millimeters, but it is too long.� Service your starter for good operation, keep the battery up, and on very cold starts, use engine preheat.
Best Regards,
Bud Yerly
www.customflightcreations.com
From: arwel pritchard (arwel.pritchard(at)powercom.ltd.uk)
Sent: Tuesday, December 1, 2020 8:51 AM
Subject: Rotax 912ULS starter motor
Good morning
Has anybody replaced the starter motor on a 912ULS with a Sky-Tec model. Apparently, it cranks the engine faster than the standard Rotax model.
I have been quoted �660 for this unit, seems quite expensive, but if it preserves the sprag clutch (which I had to replace last year at much more cost) its got to be a good thing?
Just wondering if it�s worth it.
