flyer532(at)gmail.com Guest
Posted: Sun Mar 14, 2021 6:29 pm Post subject: Volt meter |
I am wanting to install a new voltmeter in my 14V Cherokee Six. What recommendations  do you have? Where would be the best place to sample the volts with the master switch on? Thinking maybe at the master switch itself but when I tried that the volts read 11V on a charged battery. Should I just come directly off the bus bar?Â
alec(at)alecmyers.com Guest
Posted: Mon Mar 15, 2021 4:14 am Post subject: Volt meter |
What voltage do you want to measure? Battery voltage? Bus bar voltage?
Wouldn’t that inform where you measure it?
| Quote: | On Mar 14, 2021, at 10:29 PM, Daryl Thompson <flyer532(at)gmail.com> wrote:
Posted: Mon Mar 15, 2021 4:29 am Post subject: Volt meter |
 Looking to keep tabs on the battery voltage but don't want to connect directly to battery and have a continuous draw when the master switch is off
On Mon, Mar 15, 2021 at 8:19 AM Alec <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Alec <alec(at)alecmyers.com (alec(at)alecmyers.com)>
> On Mar 14, 2021, at 10:29 PM, Daryl Thompson <flyer532(at)gmail.com (flyer532(at)gmail.com)> wrote:
skywagon185(at)gmail.com Guest
Posted: Mon Mar 15, 2021 10:38 am Post subject: Volt meter |
You could use a 3 position swt. to toggle between battery, bus and off.
On Mon, Mar 15, 2021 at 5:31 AM Daryl Thompson <flyer532(at)gmail.com (flyer532(at)gmail.com)> wrote:
| Quote: |  Looking to keep tabs on the battery voltage but don't want to connect directly to battery and have a continuous draw when the master switch is off
jluckey(at)pacbell.net Guest
Posted: Mon Mar 15, 2021 11:27 am Post subject: Volt meter |
The Master is no bueno because it's ground-seeking, so you are seeing the voltage drop thru the master solenoid coil.
In my Cherokee, I ran mine from the back of the cigarette lighter cuz it was close to where I mounted my voltmeter and it is already fused.
Just make sure you feed the voltmeter through a fuse or breaker.
-Jeff
On Sunday, March 14, 2021, 07:37:46 PM PDT, Daryl Thompson <flyer532(at)gmail.com> wrote:
Posted: Mon Mar 15, 2021 11:28 am Post subject: Volt meter |
For all practical purposes voltage are equal
across the bus structure. You can tie the add-on
voltmeter to any source on the bus. It's not
uncommon to simply tap an existing breaker . . .
no new breaker or needed.
The only time you're going to read 'battery voltage'
is if the alternator is not running. So as soon
as you power up the bus but before starting
the engine, the meter displays LOADED battery voltage
for what ever accessories are presently turned
on.
out of that stuff?"
