		docclv(at)windstream.net Guest
				 Posted: Wed Jun 23, 2021 9:17 am    Post subject: Sherwin-Williams Paint |
				David:  Sherwin-Williams Acry Glo Paint weighs 0.0061-0.0084 lbs. /
 square ft per dry mil coverage, a gallon covers 800-815 square ft per
 dry mil coverage and the dry weight paint to cover an RV10 is 45 pounds,
 You should be able to estimate the amount of paint you should need.  Go
 to Sherwin-Williams, Aerospace Coatings, Product Data for this info.
 Good luck.  There is a real skill in painting a plane.  Doc
		kilocharlie767(at)gmail.c Guest
				 Posted: Wed Jun 23, 2021 9:25 am    Post subject: Sherwin-Williams Paint |
				I weighed mine before and after paint.  It added 40ish lbs.
 Ken
 Sent from KC
  	  | Quote: | 	 		   On Jun 23, 2021, at 12:21 PM, Doc <docclv(at)windstream.net> wrote:
  David:  Sherwin-Williams Acry Glo Paint weighs 0.0061-0.0084 lbs. / square ft per dry mil coverage, a gallon covers 800-815 square ft per dry mil coverage and the dry weight paint to cover an RV10 is 45 pounds, You should be able to estimate the amount of paint you should need.  Go to Sherwin-Williams, Aerospace Coatings, Product Data for this info.  Good luck.  There is a real skill in painting a plane.  Doc
