		docclv(at)windstream.net Guest
				 Posted: Wed Jun 23, 2021 8:07 am    Post subject: RV10 Painting |
				David:  I don't know the surface area of a 10 but it takes 20lbs of
 JetGlo to cover the Fuselage and 25lbs of JetGlo to cover the rest of
 the plane when the paint is dry.  I hope this helps.  Doc
  |  | - The Matronics RV10-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rjones560xl@gmail.com
  Joined: 29 Jul 2015 Posts: 64 Location: Las Vegas, NV
				 Posted: Wed Jun 23, 2021 3:44 pm    Post subject: RV10 Painting |
				My RV10 (N810RK) gained about 35 pounds when it was painted.  It was painted by T&P at Salinas, CA. Juan and his crew do good work but they are not the cheapest. I painted all the fiberglass with Evercoat feather fill and blocked it down a bit before they got it. They probably sanded most of the feather fill off, but at least I got all the pin holes filled. That probably accounts for the small difference in finished weight. I ended up at 1,749 lbs empty. Dynon 3 screen panel, dual ADAHARS, Garmin 650 and Dynon 3 axis autopilot. I think it could be built a little lighter with all my equipment, but not a lot. I reenforced the pants with carbon fiber where they mount and a number of other high stress areas as well. The bottom (Showplanes) cowl was split to make it a one man cowl. All those things added some weight, but were worth it to me. I have a Barrett 540X with cold air induction that puts out 290 hp. I flight tested to 3,000 lbs gross weight, but rarely fly it over 2,500 pounds.
 Robert Jones
  	  | Quote: | 	 		   On Jun 23, 2021, at 9:12 AM, Doc <docclv(at)windstream.net> wrote:
  David:  I don't know the surface area of a 10 but it takes 20lbs of JetGlo to cover the Fuselage and 25lbs of JetGlo to cover the rest of the plane when the paint is dry.  I hope this helps.  Doc
  _________________ Robert J Jones
702-521-1840 |
