RV10 Performance
Goto page Previous  1, 2
amekler
PostPosted: Tue Oct 05, 2021 4:32 am    Post subject: RV10 Performance Reply with quote
Go to their web siteDownload the flight data forms and fly
Then email them in
When I got rid of gam they had me start with their stock size injections
On Oct 4, 2021, at 10:59 PM, Robert Jones <rjones560xl(at)gmail.com> wrote:
Thanks. I think I will call them. I need to make sure my Dynon EMS is set for high resolution and harvest some data first.
Robert Jones
On Oct 4, 2021, at 2:57 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
I had no luck with gamiAirflow performance was great
Highly recommend
On Oct 4, 2021, at 4:21 PM, John William Cox <rv10pro(at)gmail.com> wrote:
Did you upgrade brake fluid to Royco 782. Big reason notvto use 5606.
Your potential fuel burn sounds right. Gami are pros on Continental. Consider Airflow Performance of Spartanburg, South Carolina for Lycoming.
On Mon, Oct 4, 2021, 09:55 Robert Jones <rjones560xl(at)gmail.com (rjones560xl(at)gmail.com)> wrote:
I am going to gather some data for GAMI to see if they can improve how even my EGT’s peak. My number 2 cylinder peaks ahead of the other 5, which are quite even. I have not been running lean of peak because of that. I think I could get my cruise fuel flow down to about 10 gal/ hr if I got my injectors tuned better. Time will tell.
I used real brake lines made up by All Hoses just down the street. I thought the Vans supplied hoses were junk. A friend of mine has a custom brake fluid reservoir with a float switch in it. If I can get him to build me one I am going to hook it up to a general purpose wire on the EMS and build an icon for the Dynon EMS screen to display low brake fluid.
I use my middle screen to display engine instruments at 100% in normal mode the numbers on a lot of instruments were awfully small and I got a friend of mine to modify the file to increase the size of the numbers on a few of them. He was so successful that I am going to have him increase the size of the numbers on the CHT’s and EGT’s and post the file here.
Robert Jones
On Oct 4, 2021, at 12:26 AM, John William Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
A wise list of components on the build and fuel burn sounds right.
Have you balanced your injectuon jets? Do you cruise Lean of Peak?
Did you use bonaco brake fluid libes and avoid Nylaflow?
John Cox
On Sun, Oct 3, 2021, 20:37 Robert Jones <rjones560xl(at)gmail.com (rjones560xl(at)gmail.com)> wrote:
--> RV10-List message posted by: Robert Jones <rjones560xl(at)gmail.com (rjones560xl(at)gmail.com)>
I completed N810RK about a year and a half ago. It was a slow build kit with lots of mods and I built my own IFR panel with 3 Dynon HDX screens and a Garmin 650. I was curious about performance in the community. I have a Barrett engine with cold air induction and a Showplanes cowl. I usually run it at 19 inches and 2300 rpm which I can hold up to 13,000 I get about 160 TAS down low and about 175 TAS at 13,000. This takes about 12.3 Gal/hr at 50 rich of peak. Does this sound about average for most of you?
Robert Jones
-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List
WIKI -
John Cox
rleffler
PostPosted: Tue Oct 05, 2021 4:56 am    Post subject: RV10 Performance Reply with quote
I highly recommend their fuel injection class when they start them up again.   I was fortunate to have Don balance my injectors after class one day.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Alan Mekler MD <amekler(at)metrocast.net>
Sent: Tuesday, October 5, 2021 8:32:11 AM
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Subject: Re: RV10-List: RV10 Performance
Go to their web site Download the flight data forms and fly
Then email them in
Robert Jones
I had no luck with gami Airflow performance was great
Highly recommend
Robert Jones
John Cox
Robert Jones
WIKI -
John Cox
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
rjones560xl@gmail.com
PostPosted: Tue Oct 05, 2021 8:58 am    Post subject: RV10 Performance Reply with quote
I found the documents. I will get with it and collect the data. Thanks for the information. You have been quite helpful in getting me started in the right direction.
Robert Jones
Then email them in
Robert Jones
Highly recommend
Robert Jones
John Cox
Robert Jones
WIKI -
John Cox
Robert J Jones
702-521-1840
amekler
PostPosted: Tue Oct 05, 2021 9:14 am    Post subject: RV10 Performance Reply with quote
I went through a nightmare with gami on my matti tuck red gold lycomingThey had me send my spider out for calibration (any it was fine)
They had me looking for intake leaks that weren’t there
They had my richest cylinder on takeoff become my leanest in cruise
I was glad to find Don Rivera
Alan
Robert Jones
Then email them in
Robert Jones
Highly recommend
Robert Jones
John Cox
Robert Jones
WIKI -
John Cox
kilocharlie767(at)gmail.c
PostPosted: Tue Oct 05, 2021 9:38 am    Post subject: RV10 Performance Reply with quote
I spoke with Don this morning. What a great source of information. Wish they offered classes, but the times are what they are.
Ken
Sent from KC
[quote] On Oct 5, 2021, at 12:18 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Alan
> Robert Jones
>> Then email them in
>> Sent from my iPhone
>>> Robert Jones
>>>> Highly recommend
>>>> Sent from my iPhone
PostPosted: Tue Oct 05, 2021 9:50 am    Post subject: RV10 Performance Reply with quote
Thanks for telling me your experience.
Robert Jones
[quote] On Oct 5, 2021, at 10:18 AM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Alan
> Robert Jones
>> Then email them in
>> Sent from my iPhone
>>> Robert Jones
>>>> Highly recommend
>>>> Sent from my iPhone
Robert J Jones
702-521-1840
PostPosted: Tue Oct 05, 2021 10:08 am    Post subject: RV10 Performance Reply with quote
I will do that. Thanks
Robert Jones
On Oct 5, 2021, at 2:23 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Right. I would expect they probably flow matched the cylinders as well. I would inspect and clean the #2 injector, then swap it with the #4 injector. That will tell you whether it is the injector or something else. If #4 becomes lean you know it is that injector. If #2 remains lean then either one of the lifters on that cylinder is not operating to spec, or there is an air leak somewhere.
> On 10/4/2021 7:38 PM, Robert Jones wrote:
> Thanks for the information. I think I will try that first. Barrett matched the injectors to all flow the same, so that may not do any good. It depends on how close they are. The other part of the equation is airflow. Getting the exact amount of air into each cylinder is probably not possible, so adjusting fuel flow to match the air flow available is probably the only way to do it.
> When I try to run lean of peak the engine starts missing some. Probably because my #2 cylinder is just too lean when the others get where they should be.
> Robert Jones
>>> On Oct 4, 2021, at 3:33 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
>> I found it useful to swap my richest injectors with the leanest first. After doing that a couple times, I found my #3&4 were consistently the richest. So I ordered 2 restrictors from Airflow that were 0.005 lower flow size, which got me within the desired 0.5 gph from richest to leanest peak. All of my EGTs run very close now, although I still get a very minor roughness when I go LOP. I have thought about trying on notch leaner yet on those two cylinders, new spark plugs and possibly an electronic replacement for one of my mags.
>> Kelly
>>> On 10/4/2021 1:24 PM, Robert Jones wrote:
>>> Thanks for the tip on Airflow Performance. I have a FM 300 throttle body, but I did not know they tuned injectors.
>>> I used 782 for my brake fluid.
>>> Robert Jones
>>>>> On Oct 4, 2021, at 1:19 PM, John William Cox <rv10pro(at)gmail.com> wrote:
>>>>> On Mon, Oct 4, 2021, 09:55 Robert Jones <rjones560xl(at)gmail.com <mailto:rjones560xl(at)gmail.com>> wrote:
>>>> will tell.
>>>> Robert Jones
>>>>> John Cox
>>>>> Robert Jones
>>>>> <http://www.matronics.com/Navigator?RV10-List>
>>>>> FORUMS -
>>>>> eferrer noreferrer"
>>>>> <http://forums.matronics.com>
>>>>> WIKI -
>>>>> <http://wiki.matronics.com>
>>>>> b Site -
>>>>> <http://www.matronics.com/contribution>
>>>> John Cox
Robert J Jones
702-521-1840
PostPosted: Tue Oct 05, 2021 10:13 am    Post subject: RV10 Performance Reply with quote
I have duel Emag 2006X electronic ignitions. With the hotter spark the engine should run LOP ok if I get the mixtures even on each cylinder.
Robert Jones
On Oct 4, 2021, at 8:40 PM, Dan Masys <dmasys2(at)gmail.com> wrote:
In spite of GAMI injectors and reasonably matched flows my -10 was never really happy running LOP until I swapped a mag for a Surefly electronic ignition. Made all the difference.
Just one plane's story,
-Dan Masys
On Mon, Oct 4, 2021 at 7:43 PM Robert Jones <rjones560xl(at)gmail.com (rjones560xl(at)gmail.com)> wrote:
Robert Jones
Robert J Jones
702-521-1840
Page 2 of 2
