Primer handle squeaky/not smooth
PostPosted: Thu Dec 30, 2021 12:46 pm    Post subject: Primer handle squeaky/not smooth Reply with quote
I recently replaced the o-ring for the primer handle and it's not very smooth to pump. I read somewhere that someone lubed their o-ring prior to installation? Any recommendations?
dsavarese0812(at)bellsout
PostPosted: Thu Dec 30, 2021 1:00 pm    Post subject: Primer handle squeaky/not smooth Reply with quote
The reason it squeaks is because the o-ring is dry.  You could very
lightly lube it with Fuel Lube which is impervious to fuel and oil.
Available from Aircraft Spruce.  A 1 lb can will last the rest of your life.
https://www.aircraftspruce.com/catalog/pnpages/09-00180.php?gclid=CjwKCAiAzrWOBhBjEiwAq85QZ14_Y3yjr5A-pdyol_3ThA9ZyB-jtOMoTOYnXx10uyTK3Jg7aBYxJxoCz9EQAvD_BwE
A. Dennis Savarese
334-546-8182
www.yak-52.com
http://forums.matronics.com/viewtopic.php?p=505541#505541
PostPosted: Thu Dec 30, 2021 1:45 pm    Post subject: Re: Primer handle squeaky/not smooth Reply with quote
Thank you, Dennis. Ordered.
jonboede(at)hotmail.com
PostPosted: Thu Dec 30, 2021 3:21 pm    Post subject: Primer handle squeaky/not smooth Reply with quote
You mean like EZ-Turn? A can of that is magic. Just the right stickiness to hold washers and bolts onto your fingers while you get your hand into the aircraft’s nether regions.
On Dec 30, 2021, at 3:06 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
The reason it squeaks is because the o-ring is dry. You could very lightly lube it with Fuel Lube which is impervious to fuel and oil. Available from Aircraft Spruce. A 1 lb can will last the rest of your life.
A. Dennis Savarese
334-546-8182
www.yak-52.com
PostPosted: Thu Dec 30, 2021 5:33 pm    Post subject: Primer handle squeaky/not smooth Reply with quote
Yes, definitely magic.
> A. Dennis Savarese
> 334-546-8182
> www.yak-52.com
flyjmz2
PostPosted: Thu Dec 30, 2021 5:46 pm    Post subject: Re: Primer handle squeaky/not smooth Reply with quote
LOL. I have the same problem, didn’t know that was a thing, ordering now. Still LOL.
Cheers.
Jesse
Jesse
Nanchang CJ-6
ziegler.jesse@gmail.com
1906
PostPosted: Fri Dec 31, 2021 9:11 am    Post subject: Re: Primer handle squeaky/not smooth Reply with quote
One more question. Any way to stop the fuel going to the primer? Last time the primer was apart, fuel as gushing out and made a big mess.
PostPosted: Fri Dec 31, 2021 10:50 am    Post subject: Primer handle squeaky/not smooth Reply with quote
Shut the fuel off by pulling the red handle to OFF.
http://forums.matronics.com/viewtopic.php?p=505552#505552
glipaz
PostPosted: Tue Feb 01, 2022 10:02 pm    Post subject: Re: Primer handle squeaky/not smooth Reply with quote
I also replaced primer o-ring and used EZ Lube. Goes up and down great. But I have fuel coming out of the top of the primer on my Nanchang.
