airmaster compatible prop choices for the mono?
peterz(at)zutrasoft.com
PostPosted: Tue May 17, 2022 12:14 pm    Post subject: airmaster compatible prop choices for the mono? Reply with quote
Now with a gearbox longevity vs prop dilemma,  I'm wondering if the lighter composite blades made for the airmaster will also fit into the WD prop hub (as a stopgap measure to not destroy another gearbox, and still keep the lottery option open for an airmaster hub down the road)?
Cheers and thx,
PeteZ
C-GNPZ
Area-51
PostPosted: Tue May 17, 2022 6:44 pm    Post subject: Re: airmaster compatible prop choices for the mono? Reply with quote
The airmaster hubs mostly use whirlwind blades which have quite a unique shaft profile.
What happened to your airmaster hub Peter?
PostPosted: Wed May 18, 2022 2:47 am    Post subject: airmaster compatible prop choices for the mono? Reply with quote
Wrt airmaster hub, i dont own one (yet?)…. Lottery purchase lol.
PeteZ
On May 17, 2022, at 10:51 PM, Area-51 <goldsteinindustrial(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=506819#506819
