'Homebuilt' voltage regulator as battery charging controller
bob.verwey(at)gmail.com
PostPosted: Fri Oct 21, 2022 2:36 am    Post subject: 'Homebuilt' voltage regulator as battery charging controller Reply with quote
Speaking of regulators..sorry for the thread hijack Charlie...
Is there a way to use an old school Ford style regulator as a battery charging device / controller id you have 16v DC input from a transformer, say?
On Fri, 21 Oct 2022 at 01:52, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> Just saw this article about the L9918 alternator regulator from ST
> Microelectronics. I'm curious about whether it might be viable as a
> replacement for the unprotected regulators still found in some of the
> older 'one wire' alternators many of us still use, or perhaps, even
> for an externally regulated alternator.
> It has a lot of sophisticated features we'd likely never use, but a
> quick stroll through the data sheet (link in the article) makes it
> sound as if it will function just fine in standalone mode. Five
> terminal device, but the 5th terminal is basically a 'comm' terminal,
> which the data sheet implies can be lost and the regulator will still
> function properly. It does have OV & UV protection built in. At a
> onesies cost of <$10, it certainly looks tempting to try.
> Charlie
Well shucks. For some reason, the link didn't 'take'. Here's the full link:
=omeda%7C0371F5910123I6U&oly_enc_id=0371F5910123I6U]https://www.electronicdesign.com/markets/automotive/article/21252965/electronic-design-automotivealternator-regulator-embeds-advanced-functionality-lin-interface?utm_source=EG+ED+Analog+%26+Power+Source&utm_medium=email&utm_campaign=CPS221013058&o_eid=0371F5910123I6U&rdx.ident[pull]=omeda|0371F5910123I6U&oly_enc_id=0371F5910123I6U
www.avast.com
WIKI -
Best Regards,Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
