t_klammer(at)yahoo.com Guest
Posted: Sat Feb 18, 2023 6:50 am Post subject: Rookie Question on RV-10 Battery Ground |
Hi, I am reading Bob’s book and am no longer sure about what a quality battery ground looks like. Do I just install a short jumper between the battery negative and the airframe? Or do I need to run a long wire from the battery negative up to the firewall/instrument panel ground bus?
Tom
Posted: Sat Feb 18, 2023 10:34 am Post subject: Rookie Question on RV-10 Battery Ground |
At 08:49 AM 2/18/2023, you wrote:
Quote: | --> AeroElectric-List message posted by: Thomas Klammer <t_klammer(at)yahoo.com>
Hi, I am reading Bob’s book and am no longer sure about what a quality battery ground looks like. Do I just install a short jumper between the battery negative and the airframe? Or do I need to run a long wire from the battery negative up to the firewall/instrument panel ground bus? |
Check out the Obrien battery installation photos
here:
https://tinyurl.com/2ysep667
A robust electrical connection to airframe is
sufficient. Also, note the welding cable
jumpers off the battery terminals . . . even
if you choose 22759 FAT wires for everything
else, welding cable battery leads make life
much more pleasant for removal/replacement
of batteries.
out of that stuff?"
