h&jeuropa
Posted: Sat Apr 15, 2023 2:50 am Post subject: Coolant Hose |
We are in the midst of the install of our replacement 914. Europa supplies a coolant hose for the inlet to the coolant pump that has a 90 degree bend and a 180 degree bend in order to have the pump inlet facing to port.
But the inlet can be rotated to face starboard. Is there is reason not to use a shorter, simpler hose that would just be a 90 degree bend to go to the coolant radiator?
Jim & Heather
SPURPURA
Posted: Sat Apr 15, 2023 4:17 am Post subject: Re: Coolant Hose |
I had to replace the 180 degree hose to the radiator and did it with a 90 degree silicone hose. I inserted a coil spring inside to keep it from collapsing and has worked well for 4 years now. You can find the spring at McMaster Carr and it works great for tight bends on silicone hoses.
_________________ N951EU - Tri-gear & 912ULS, N77EU- Tri-gear & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. |
rogerabc
Posted: Sat Apr 15, 2023 4:51 am Post subject: Coolant Hose |
Hi Jim,
I think the pipe will have to bend in order to avoid the ring mount.
Sounds worth a try.
Roger
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=510622#510622
