Fwd: For Sale - Kolb Mark III Light Sport Aircraft Project
rrh(at)rrhoyt.com
PostPosted: Mon Sep 11, 2023 4:03 pm    Post subject: Fwd: For Sale - Kolb Mark III Light Sport Aircraft Project Reply with quote
-------- Forwarded Message -------- Subject: For Sale - Kolb Mark III Light Sport Aircraft Project Date: Mon, 11 Sep 2023 14:39:42 -0500 From: Ron <rrhoyt(at)ieee.org> (rrhoyt(at)ieee.org) To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)
Completed phase I flight testing and flown 150 hrs before a Major Modification. Major Modification flight testing completed. Some parts removed. De-registered as an Experimental Armature Built aircraft.
I have another project for some of the parts and I need more room in the hanger. The air frame has a Rotax 912 engine with an IVO 3 blade Prop. An ideal engine for this two place experimental aircraft. The project is located in the Minneapolis MN area and I'm asking $11,000. See pictures on Craigslist.
Details:
1/ Air frame has approximately 150 hours flight time, always hangered. First flew around 2011. One owner.
2/ Steel cage is powder coated. All steal parts powder coated. Poly Fiber covering.
3/ Full right side controls (Stick and rudder). Single throttle in center.
4/ No basic instruments included. The panel contains a radio, a transponder (mode S), hole cutouts for 3 steam gauges and a tachometer for the 912.
5/ Modifications include: BRS parachute, wing fuel tanks with cockpit controlled shut-off valves, Dual flight control seats, energy absorbing landing gears, drooped wing tips, elevator trim with controls in cockpit, aileron trim with controls in cockpit, Engine radiator used to heat cockpit, enlarged cockpit with gull wing doors.6/ Energy absorbing landing gears meets FAA FAR part 23 requirements. OEM landing gears facilities remain and may be used to replace the installed system
7/OEM seats were replaced without disturbing OEM sling seat facilities. Foam padded seats with metal structure to prevent hip/spine injury in a hard landing which meets the UK(British) requirements.
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
