Tire Size
Kellym
PostPosted: Mon Sep 25, 2023 1:03 pm    Post subject: Tire Size Reply with quote
Since there has not been too much discussion on this list lately, I
bring you a question that has been on my mind from tome to time.
Do you use the main wheel size that Van's recommends or something else?
Kelly
Kelly McMullen
KCHD
Tim Olson
PostPosted: Mon Sep 25, 2023 1:13 pm    Post subject: Tire Size Reply with quote
I've stuck with the 15-6.00x6.
Tim
Kelly
philperry9
PostPosted: Mon Sep 25, 2023 1:59 pm    Post subject: Tire Size Reply with quote
I have stuck with the standard and ran Dresser re-treads. It’s worked well for me, so I can’t really justify changing it.
Tim
> Since there has not been too much discussion on this list lately, I bring you a question that has been on my mind from tome to time.
> Kelly
Coop85
PostPosted: Mon Sep 25, 2023 2:25 pm    Post subject: Tire Size Reply with quote
Same here. 27 years and 1200+ hours with no regrets.
Marcus
> Tim
>> Kelly
Marcus Cooper
RV-10 since 2006
Kellym
PostPosted: Mon Sep 25, 2023 3:14 pm    Post subject: Tire Size Reply with quote
Interesting that only two replied, and stuck with Van's 15x6:00x6. I so
far have also stuck with that, but have thought about changing to
6:00x6. Cost is but one factor.
Kelly
On 9/25/2023 2:58 PM, Phil Perry wrote:
I have stuck with the standard and raat n Dresser re-treads. It’s worked well for me, so I can’t really justify changing it.
> Tim
>> Kelly
Kelly McMullen
KCHD
Dave Saylor
PostPosted: Mon Sep 25, 2023 4:30 pm    Post subject: Tire Size Reply with quote
Same here, standard Van's for me.
I do know someone who used the same tires and wheels as a Bonanza. They
seemed HUGE compared to mine. Something about "just wanting more tire". K
--Dave
KWVI
dan(at)syz.com
PostPosted: Mon Sep 25, 2023 10:57 pm    Post subject: Tire Size Reply with quote
I had a lot of problems with main wheel shimmy and switching to the larger standard sized 6.00x6 Dresser retreads improved things a lot. But I had to modify my already-fitted wheel pants to accommodate them by enlarging the hole the tires poke through, and relocating the axle mounting hole on the wheel pants to “twist” them slightly to avoid interference along the top. If I had to do it again, I would have done the wheel pants with this specifically in mind, as standard sized 6.00x6 tires are easier to come by. But it works in the end.
I do know someone who used the same tires and wheels as a Bonanza. They seemed HUGE compared to mine. Something about "just wanting more tire". K.
On Mon, Sep 25, 2023 at 3:02 PM Phil Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
--> RV10-List message posted by: Phil Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
> On Sep 25, 2023, at 4:16 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
> --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
> Tim
>> --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
>> Kelly
WIKI -
Bob Turner
PostPosted: Fri Sep 29, 2023 1:21 pm    Post subject: Re: Tire Size Reply with quote
Stock size for me, but always a hard surfaced runway (so far).
Bob Turner
RV-10 QB
