Prop adjustment M-14p
glipaz
PostPosted: Fri Jul 05, 2024 6:29 pm    Post subject: Prop adjustment M-14p Reply with quote
Asking the smarties on here.
I fly a Nanchang with a stock M-14p motor and an MT 250 prop. When I push the nose down my RPMs increase without touching the prop lever.
Assuming the governor is set up properly, if my RPMs increase when I go downhill would it be a spring issue in the governor?
Gil
Ttail
PostPosted: Fri Jul 05, 2024 8:28 pm    Post subject: Re: Prop adjustment M-14p Reply with quote
Presuming you have the "Stronger" spring GiL.
I previously had an MT250 fitted as well even with the Stronger spring it exhibited a little of this behaviour.
I now have a 265cm MC400C from Whirlwind aviation fitted it still exhibits a little of this.
(BTW IMO the Whirlwind prop in formation (Straight and form aeros) is a dramatic improvement over the previously fitted MT prop, and far more robust in rain etc)
Sean Trestrail
ttail[at]internode.on.net
glipaz
PostPosted: Fri Jul 05, 2024 8:52 pm    Post subject: Re: Prop adjustment M-14p Reply with quote
Yes, I sent the governor to MT for a stronger spring.
