Paul Hawkins
Joined: 05 Jun 2011 Posts: 10 Location: BIGGIN HILL UK
Posted: Fri Nov 08, 2024 7:26 am Post subject: PV-50 Prop settings |
Hi
Many thanks for your responses and recommendations for a replacement prop much appreciated and a special thanks to Bob, when he posts it always reminds me every day is a school day.
cheers Paul
Sent: 24 March 2022 15:00
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: PV-50 Prop settings
Hi
Some advice please on prop settings, my Europa has a 914 engine with an Arplast PV-50 prop in fine pitch it’s set to give just under 5400 rpm static and on take-off works as it should the problem is when I set to cruise I aim for 130 Kts but I have to keep coming back on the throttle not to go above that speed I end up with 130 Kts with an rpm of 4200 the problem started after a prop service, normally I tend to cruise at 125/130 for 4650/4700 rpm-ish, there’s 10° difference between fine and coarse pitch, which way should I adjust + or – the 10° prop difference?
Cheers Paul
