What did you do with your Europa this week 10/01/25 (Area-5
erichdtrombley(at)juno.co
PostPosted: Sun Jan 12, 2025 7:22 am    Post subject: What did you do with your Europa this week 10/01/25 (Area-5 Reply with quote
LOL. High end laboratory tools are essential, no doubt. Looks like you are making great progress on the engine.
Area-51
PostPosted: Mon Jan 13, 2025 6:28 am    Post subject: Re: What did you do with your Europa this week 10/01/25 (Ar Reply with quote
Yes its turning out to be a good purchase. Bit more work than expected to bring it up to scratch, but so far it is measuring up very well. It will be a stop gap for 181 while the 912iS gets overhauled and prepped for installation.
PostPosted: Sun Jan 19, 2025 10:18 am    Post subject: What did you do with your Europa this week 10/01/25 (Area-5 Reply with quote
Thanks Area-51. I had no ideal it was such a labor intensive endeavor. I really thought you blasted the components with walnut shells or the like. The end result does truly look great!
Area-51
PostPosted: Sun Jan 19, 2025 2:19 pm    Post subject: Re: What did you do with your Europa this week 10/01/25 (Ar Reply with quote
Walnut shell blasting would be a lot easier but would require adaptors and a walnut blaster. Or vapor blaster tank for cylinder heads. I am unable to trust the engine rebuilders against dropping stuff and damaging the sealing surface; so i do the cleaning and lapping myself. If i start doing more engines will probably invest in much high end laboratory equipment. 😂😂😂
