docclv(at)windstream.net Guest
Posted: Fri May 23, 2025 11:00 am Post subject: RV 10 replacement struts |
Guys: I see that I listed the Bansbauch EasyLift part number wrong.
The correct number is B0N0F50-100-247-600N (only one B and one N). It
has basically the same measurements (rod size, cylinder diameter, etc.
except total length (287 mm for the A1A1 vs 297mm for the B0N0 with the
B1 M8 ends). Van's Strut is 298.5 mm. Door will open the same
distance! # 41087 and 41862 Doc
