docclv(at)windstream.net Guest
Posted: Thu May 15, 2025 6:19 am Post subject: RV 10 Wing Tip Mounting |
We Built 2 RV 10's. Messed up the first wing tip on the first 10.
Solution was to not cut the wing tip mounting lip off but to mount it as
sent from the factory and Epoxy-fiber in the remaining mounting recess
to the contour of the wing. Wing span is now 32 feet instead of 31-11.
Perfect fit. Carroll Verhage 41087 and 41862 N123CV and N784DC
