dave
Posted: Mon Oct 23, 2006 7:41 am Post subject: Don Smythe comments on Warp Angle and Movie |
Ok Don, I just out in hangar and measured the prop about 6 inches in from
tip
results were 2 blades about the same and third one out 1/2 to 3/4 degree
or so.....
At tips all three I would say within 1/4 degree.
So you say most of thrust is coming from the 3/4 point out the length of
the blade which might be correct but if that is they what about the longer
the prop, the better the climbout as a rule ?
So , my question is what is the relevance ?
And what performance gain is there to be had ?
You saw the Trailerpark videos ? http://www.cfisher.com/kitfox/
Takeoffs 4 to 6 seconds
What will I gain? thoughts ?
I need comments -- are my takes offs OK ? Am I missing something ?
Maybe my prop is costing me performance ?
How does mine compare to others ? 582 or 912s ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dosmythe(at)cox.net Guest
Posted: Mon Oct 23, 2006 9:39 am Post subject: Don Smythe comments on Warp Angle and Movie |
Dave,
It was a NASA Engineer that educated me about the max thrust being
produced somewhere in the 2/3 range. You are the first one to ever come
back and say that he checked the prop and found the same differences that I
did. Now, what is the relevance you ask??? I don't have a clue. However,
I think that all would agree that the three blades should be adjusted with
exactly the same pitch to reduce vibration etc..... If I have a problem
adjusting at the tips and getting all blades exactly the same then I should
look for a better way. I found that my blades were linear all the way from
the hubs to within 2+ inches of the tips. Adjusting at the 2/3 point
ensures the blades are all very close and who cares about the last 2 inches
(tips) that do very little.
BTW, there is no performance gain on picking a spot to adjust the props.
Any place is fine as long as you use the exact same spot on each blade
except the tips (IMHO)
Don Smythe
Float Flyr
Posted: Mon Oct 23, 2006 3:08 pm Post subject: Don Smythe comments on Warp Angle and Movie |
Hoo boy!
Just try putting a prop that is two inches longer or shorter for that
matter, on your plane before you say the last 2 inches do very little.
Don't forget the last two inches travel the fastest and travel the furthest.
On seaplanes you will find the most pitting on the tips of the blades where
spray erodes the leading edges. On metal blades dressing the pits out to an
extent will smooth out the prop and increase thrust. On composite
propellers filling the pits with epoxy and then dressing back to the
original surfaces will do the same thing.
Noel
who cares about the last 2 inches (tips) that do very little.
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 23, 2006 9:30 pm Post subject: Don Smythe comments on Warp Angle and Movie |
Well, Since my airplane is just outside the side door, I did the deed. I
just checked the prop pitch. I usually pitch my Warp taper at the inboard
end of the nickel leading edge - the same as everyone else I have talked to.
All checked the same there. And the same to about three inches from the
tip, but two inches in, big difference and one was a full bubble witdth flat
at the tip. Now, I am not particularly happy with my findings, but I am
glad the bulk of the blade is pitched the same as the others. Kudos to Don
and his aeronautical engineer friend.
Are you suggesting that the terminal two inches is the major player in prop
efficiency and smoothness? And a full bubble width - 2 degrees out of pitch
is better at the fat of the blade than the final inch or two of the tip?
Hoo Boy!
Won't argue the merits of blade length here. I thought we were talking
about blade pitch and where to put the protracter.
Lowell
Posted: Tue Oct 24, 2006 3:43 am Post subject: Don Smythe comments on Warp Angle and Movie |
Lowell my friend,
Thanks but I want to know what took you are so long to check this?
Ha.... I only reported it about 5 years ago. It was then that I called
Warp with your same findings. This is where they will say, "NO WAY,
IMPOSSIBLE".
Rather than some get in a huff about this thread, simply do like Lowell
did and check your prop and report the findings. If every warp prop is the
same way then warp would have to admit it. Whether they do or not, at least
the List (a select few) would benefit.
Don Smythe
dave
Posted: Tue Oct 24, 2006 4:10 am Post subject: Don Smythe comments on Warp Angle and Movie |
Don,
Having found this in the first place did you try different settings?
e.g. setting at the 75% the same pitch and having different degree
settings at tip and was there any noticeable difference in performance
and/or vibration ?
I will be doing some testing here next day or two I hope. We under heavy
snow right now but looks ok for tomorrow so far .
Also mine does seem to work ok now an maybe in fact it not even adjust
optimally.
Dave
Posted: Tue Oct 24, 2006 6:12 am Post subject: Don Smythe comments on Warp Angle and Movie |
I think I stated this earlier but, I placed a steel machinist rule against
the hub and marked off every two inches toward the tips (all three blades).
I then set the pitch of all three blades at the 20" mark to 26 degrees (I'm
using memory on those numbers). Once done with that, I went back and
checked the pitch of each blade on each of the 2" marks and recorded. Every
recorded pitch angle was very close until I got to the last 3" and then saw
angle differences up to 1 or more degrees.
Again, I did not notice any vibration difference. Performance will be
determined as to what angle you pitch not where you pitch at. As a second
thought, I never used the tips as an adjustment point and flew the plane so
I don't know if it might affect vibration or not..
Don Smythe
Float Flyr
Posted: Tue Oct 24, 2006 7:51 am Post subject: Don Smythe comments on Warp Angle and Movie |
Lowell:
Regardless of where I think the measurements should be taken, I would take
the measurements where the manufacturer says to ( my AME training again).
If GSC says to measure their blades at .61 the length then on the GSC that's
where I take the measurements. If the Warp people say to measure their
blades at the tip then I have to assume they have their reason for measuring
that way and that's where I would measure the Warp blade. I do however find
it interesting that they measure their pitch at that location.
The last post I made on the length of the blade was in response to someone
who thought the tips of the blade did very little... Of course if that were
true they would shorten the blade wouldn't they.
Noel
[quote] --
Kitfox III-A
Guy Buchanan
Posted: Tue Oct 24, 2006 8:26 am Post subject: Don Smythe comments on Warp Angle and Movie |
At 06:59 AM 10/24/2006, you wrote:
| Quote: | My guess in all this is that the nickel leading edge has some memory and
when it is bonded to the prop blade, the only place it can unwind and have
any influence is at the thin tip.
I'm got about 1/2 bubble width out, with no nickel leading edge. I suspect
it's the usual problem with thick composite laminates. When you transition
from thick to thin it's easy to have problems maintaining symmetry in the
laminate. Builders typically use very thick plies to make the laminating
faster and a little asymmetry in the bias ply trimming, or a little angle
to the uni's and you get warps.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Tue Oct 24, 2006 8:27 am Post subject: Don Smythe comments on Warp Angle and Movie |
Jus curious ... Do all the blades have a consistent difference of pitch at
the tips or does the difference vary with the blade??
Noel
[quote] --
Kitfox III-A
Posted: Tue Oct 24, 2006 9:45 am Post subject: Don Smythe comments on Warp Angle and Movie |
I'm not sure I quite understand the question but, when I checked mine I
simply took all the readings and compared the difference. For instance, if
I measured at 22" and got 24 degrees 24-1/4 degrees and 23-3/4 that's a
total max difference of 1/2 degree. At the tips I might have seen 12
degrees 12-3/4 degrees and 14 degrees. That's a max error of 2 degrees. I
did not make any determination that any one blade was causing the error.
Besides, all three blades tracked very close out to the tips.
Posted: Tue Oct 24, 2006 12:27 pm Post subject: Don Smythe comments on Warp Angle and Movie |
Noel,
I don't agree with your conclusions on the tip length comment. The issue is
how much of the blade you want to be in pitch. My measurements last evening
agreed almost exactly with Don's measurements, except to the extent of the
twist difference in the last inch of the one blade, mine exceeded one
degree - I got 2 degrees. In fact and I have to say this, when you are
measuring prop pitch and the bubble settles completely out side of the
lines, you just know the protractor slipped. I repeated the blades numerous
times and no slip.
Don reported his findings to Warp and they stated, "Impossible". We get
this sometimes on the list as well, people doing careful measurements and
tests and the unbelievers arguing against the results. One example comes to
mind - a guy, very careful and methodical, in my opinion and worth listening
to and still a frequent contributor to the list, reported on the results of
tests done on his airplane with vortex generators. His conclusions as far
as his results went: gentler stall characteristics but little if any
significant reduction in stall speed. Lots of arguments as to why his
results were wrong and suggestions on how he could improve the data to agree
with preconceived notions about vortex gererators, i.e., every one knows
vortex venerators reduce stall speed.
This exact thing happened on the Lancair list when one man with sets of both
plain wingtips and the winglet wing tips. He flew some tests and reported
reduced cruise speed with the winglets. Nearly all to a man agreed that his
tests were somehow flawed, despite the fact that this was the only hard
evidence using the same airplane, same pilot in similar conditions with both
types of tips. They look cool and are expensive and hard to install, so
they must be good for performance, besides the commercial jets use them,
isn't that enough reason to put them on my Lancair. Go for it I say.
I see the same thing emerging on this thread, i.e. Warp claims their blades
are symmetrical from hub to tip - pitch at the tip. A guy does careful
measurements and finds Warp is wrong at least with regard to his blades and
decided to pitch at 75%. for that reason. Warp? Impossible. I measure mine
and my measurements agree with Don. His suggestion is that we all measure
our blades and if a significant number are "warped", notify Warp and maybe
they will acknowledge a problem and change their "book", as in by the.
Instead we get lots of talk about measuring by the book etc. and good enough
for me. (Please read Guy Buchannans related post - He is in the busines).
The 2" at the tip only came in with regard to whether you preferred the four
square inches at the tip being in pitch or the 90 or so square inches in the
rest of the blade being in pitch. I think his comment to be right on - it
is best do disregard the 4 square inches and pitch for the bulk of the blade
as the 4 in. sq to be minimal in effect by comparison. No one suggested
cutting off the offending prop tips.
Lowell
Float Flyr
Posted: Tue Oct 24, 2006 3:34 pm Post subject: Don Smythe comments on Warp Angle and Movie |
Thanks ... That is what I was wondering. I don't mind saying I find it
strange that Warp requires you to set your blades by the tips when that
evidently is where the largest discrepancy appears to be.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Tue Oct 24, 2006 5:17 pm Post subject: Don Smythe comments on Warp Angle and Movie |
Lowell:
Don't get me wrong.... I'm not suggesting any one go out and hack a couple
of inches off their props.
I'm getting the feeling that in specifying the pitch angle be set by the
tips, Warp may be wrong and in fact the optimum place probably is close to
the .75 station. In my first post on this topic I did say my training was
to set pitch at .66 station that's a difference of about 3 inches on a 68"
prop.
Someone said the last two inches don't make any difference to the prop.....
It is only my contention that they sure do make a difference. If you guys
are getting large differences in pitch angle only at the tips it says to me
there is something not quite right with the blades. If so, that's an issue
I'd take up with Warp. Sounds like there is a problem there whether Warp
likes it or not.
As for how much of the blade is in pitch I agree with you that should be the
issue. The more of the blade in equal pitch the smother the blade should be,
assuming the tracking is consistent, which you have said it is.
On the question of vortex generators, winglets etc. Thee are so many
variables there that the only way to see what works for you is to try it.
Lets face it nothing is perfect and sticking a few VGs on a good wing is not
likely to make a huge difference. Putting the same VGs on a poorer wing
could have more effect.
As you said the big jets use winglets supposedly not because they fly faster
but they are supposed to save fuel on the long haul at altitude. I think
Boeing actually recommends not to have the winglets for regional airlines
flying the 737 - 700 as they seldom get to an extended cruise altitude
definitely outside the Lancair envelope. Yes the winglets look cool and if
you have the ca$h to put them on ... Why not??? Just don't expect the huge,
or any increase in speed. If you went the full gambit and added VGs, wing
fences, slats, slots, droops and winglets to the Kitfox you may never get it
off the ground.
Noel
I keep trying to remember.... Oh yes ... Do not archive.
[quote] --
Kitfox III-A
