sportav8r(at)gmail.com Guest
Posted: Mon Oct 23, 2006 5:03 am Post subject: alternator autopsy |
Bob:
I just talked to my local mechanic. He feels sure that replacing the
Hyundai's IR alternator will cure the problem I've described to him.
I asked about the possibility of an off-site regulator function in the
car's computer, and he said as far as he knew, only Dodge has tried
that stunt. We will soon find out if he's right.
I figure he's going to want the old alternator for a core at the auto
parts place, but perhaps we could gut the regulator out first, if that
would be of any help to you? Tell me what you're thinking and I'll
try to accomodate. Maybe I can pay the core charge up front and
recoup it later when you've returned everything.
Thanks for all your help with airplanes and things electric.
-Bill B
echristley(at)nc.rr.com Guest
Posted: Mon Oct 23, 2006 6:15 am Post subject: alternator autopsy |
Bill Boyd wrote:
<sportav8r(at)gmail.com>
Bob:
I agree with the mechanic. It will fix the problem, because when he
puts the new alternator in, he will tighten the loose connection that is
causing the intermittent failure. The problem you describe is classic
behaviour for a loose connection. Of course, I guess the loose
connection doesn't necessarily have to be external to the alternator. A
broken internal wire would create the same havoc.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
flyadive(at)aol.com Guest
Posted: Mon Oct 23, 2006 8:25 am Post subject: alternator autopsy |
nuckollsr(at)cox.net Guest
Posted: Mon Oct 23, 2006 10:14 am Post subject: alternator autopsy |
At 09:01 AM 10/23/2006 -0400, you wrote:
Bob:
Unless this is a platinum plated alternator, the
core value is typically 15 to 25 dollars. He
can just keep the core and add the core value to
your bill.
If it's more than $50, I'll pass but up to that
amount is okay with me.
| Quote: | Thanks for all your help with airplanes and things electric.
My pleasure sir . . . wouldn't do it if it wasn't
fun.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Mon Oct 23, 2006 10:20 am Post subject: alternator autopsy |
At 10:14 AM 10/23/2006 -0400, you wrote:
<echristley(at)nc.rr.com>
Bill Boyd wrote:
>Bob:
I agree with the mechanic. It will fix the problem, because when he puts
behaviour for a loose connection. Of course, I guess the loose connection
What we think we know about the generic automotive alternator
today is that once turned on, they stay on until the engine
stops rotating.
| Quote: | A broken internal wire would create the same havoc.
Yup . . . and if the intermittent connection were in
a low-current, control-function then no sparks or fire
would be expected. The external intermittent in an
always-ON alternator would have to be in the b-lead . .
mucho heating, sparks and maybe fire. Is a puzzlement . . .
sales(at)6440autoparts.co Guest
Posted: Mon Oct 23, 2006 11:18 am Post subject: alternator autopsy |
Could be the chassi brain box causing a problem also. I think
Barry may be right about that. A lot of automobiles these days depend on the
brian box to tell it when to charge. Yep they are too complicated.
Randy
Posted: Mon Oct 23, 2006 1:03 pm Post subject: alternator autopsy |
The $50 figure is my own experience this spring when I bought an IR
alternator for the RV long before I pulled the Van's Honda 35A unit to
make the swap. I was charged 50 bucks by the Advance Auto store and
got it all back when I returned the core several months later. (never
mind it was a Mitsubishi alternator I bought and a Honda core I gave
them back).
Since the alternator has 175,000 miles on it, I'm not crying over its
replacement even if it's not the central fault in the scenario. It's
high-time and due for a rebuild, in my book. The engine was replaced
with a low-time pull about two years ago, hence it has about 60k on
it. The computer I'm not sure about, but probably was original to the
chassis.
-BB
On 10/23/06, Robert L. Nuckolls, III <nuckollsr(at)cox.net> wrote:
>Bob:
your bill.
fun.
Posted: Mon Oct 23, 2006 2:07 pm Post subject: alternator autopsy |
Hi Randy:
I did not say it was the brain box, someone else said that .. NOPE not that .. MUCH simpler than that.
Barry
Posted: Mon Oct 23, 2006 2:08 pm Post subject: alternator autopsy |
Over Engineering again, I see.
NOPE!
khurst(at)taroom.qld.gov. Guest
Posted: Mon Oct 23, 2006 2:35 pm Post subject: alternator autopsy |
Barry,
Why do you play this game of "I've got a secret" ?
Forgive me, but I thought this was a forum where ideas are exchanged.
With respect
Kingsley in Oz
> NOPE!
Sorry Guys, that is NOT the problem. I said it before, don't you remember ... What I gripe about ALL the time when it comes to planes, it is the same problem with Hyundia ...
You are only throwing good money after bad ... Believe me .. I went through this problem for TWO MONTHS .. YUP! I was stupid, I did not listen to my own advice.
Barry
lists(at)stevet.net Guest
Posted: Mon Oct 23, 2006 4:09 pm Post subject: alternator autopsy |
Has anyone checked the engine ground strap?
Best Regards,
Steve Thomas
____________________________________________________________________
On Oct 23, 2006, at 3:36 PM, Kingsley Hurst wrote:
[quote] Barry,
With respect
Kingsley in Oz
> NOPE!
Barry
ntribution
| [b]
Posted: Mon Oct 23, 2006 5:28 pm Post subject: alternator autopsy |
At 05:07 PM 10/23/2006 -0700, you wrote:
| Quote: | Has anyone checked the engine ground strap?
Excellent! Wish I'd thought of that.
FLYaDIVE(at)aol.com Guest
Posted: Mon Oct 23, 2006 6:38 pm Post subject: alternator autopsy |
In a message dated 10/23/06 6:39:37 PM Eastern Daylight Time,
khurst(at)taroom.qld.gov.au writes:
| Quote: | Barry,
With respect
Kingsley in Oz
Thank you Kingsley:
Why indeed ... Because so many of you follow the leader with heads stuck so
far up their butts that it LQQKs like the heads are in the right place.
It is NOT a game of I've got a secret, I TOLD the secret MANY, MANY times but
you (the collective) refuse to listen. Do you recall what I posted? Do you
recall the mindless regurgitation of how I was wrong. Well, this is just an
example of Over Engineering and Electronic Babble. Remember I have screamed
about K.I.S.S. ME
I have a Hyundai, I spent two months swapping alternators, bench checking
alternators and even replaced the battery (Didn't I tell fellow that replacing
the battery won't help!) ALL to no avail. I failed to listen to my own advice.
I kick myself in the ass on that one.
"Forgive me, but I thought this was a forum where ideas are exchanged." -
Ideas are not exchanged here, only regurgitated. And if someone does not agree
with the herd. They are whipped with the entrails of the herd.
You know Kingsley, you are the ONLY one to question my posts on this topic.
The ONLY one to ask. Hell, "the only stupid question is the one not asked".
Look at how many questions were not asked!
Someone finally did respond with what I believe to be the correct answer.
Yet, we may never know. Even if they and I are right.
Last hint: There are No such freek'n things as ground loops in a DC circuit.
And what is the common metal on both the plane and Hyundai?
"With respect" - Thank you for the respect, but all I want is a nation that
thinks for themselves.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
steve(at)theagile.net Guest
Posted: Mon Oct 23, 2006 7:15 pm Post subject: alternator autopsy |
FLYaDIVE(at)aol.com wrote:
| Quote: | Last hint: There are No such freek'n things as ground loops in a DC circuit.
Hmm... I'm reminded once again of the old adage that genius has it
limits but ignorance knows no such bounds.
Steve
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Mon Oct 23, 2006 8:34 pm Post subject: alternator autopsy |
Barry,
The false assumption that undermines your argument is that we are all paying
attention to what you are saying. Some of us get really tired of trying to
sort the wheat from the chaff and just hit the delete key. I'm pretty sure
you are a smart guy that knows a lot of stuff about little airplanes that I
don't, but this air of superiority just doesn't cut it with me and I would
guess a few others.
I don't think it's Kingsley that has his head up his butt. If you want to
show us a little respect by making your posts short and to the point without
belittling the character or intelligence of the rest of us, go for it. If
not, don't expect us to remember just what it is that you have been saying.
We probably hit the delete key before we got to it.
And enough with this Yamashiada crap!
Terry
Posted: Tue Oct 24, 2006 3:34 am Post subject: alternator autopsy |
Barry,
| Quote: | Why indeed ... Because so many of you follow the leader with heads
stuck so
| Quote: | far up their butts that it LQQKs like the heads are in the right
place.
Strange that ! 'cause after three years on this list, I am far from
reaching the same conclusion. If you had said that a few on this list
think they are mightier than thou, then I think I may have been able to
concur.
| Quote: | It is NOT a game of I've got a secret
Then what is it ? Is it just that if one person on the list disagrees
with you that you then withhold your knowledge ? Or are you the type of
person who only says things once and anybody who simply misunderstands
or can't recollect, gets ignored ?
| Quote: | I TOLD the secret MANY, MANY times but
Sorry but I as part of the 'collective', DID NOT REFUSE TO LISTEN and
NO, I don't recall what you 'singular' posted !
| Quote: | Do you recall the mindless regurgitation of how I was wrong.
NO again. Starting to wonder if you have a complex !
| Quote: | Well, this is just an example of Over Engineering and Electronic
Babble.
Not what I would have called it !
| Quote: | Remember I have screamed about K.I.S.S. ME
Actually I do remember something about that but I'd rather decline the
offer thank you.
| Quote: | I have a Hyundai, I spent two months swapping alternators, bench
checking
replacing
Well I haven't got a Hyundai so it matters little to me now whether you
tell me or not.
| Quote: | You know Kingsley, you are the ONLY one to question my posts on this
topic.
Fat lot of good it did me, you didn't answer so what was the point of my
asking ?
| Quote: | Hell, "the only stupid question is the one not asked".
I'll need time on this one . . . . question to myself . . . . . "how can
a question be a question (stupid or otherwise) if it is not asked ?"
thinking . . . . . . . thinking . . . . . . . . .
| Quote: | Someone finally did respond with what I believe to be the correct
answer.
????? I'm bewildered. Are you now saying you may NOT be right ?
circuit.
Ah ! well at least I now know it is not caused by a Ground Loop. Even
I know that things that don't exist don't cause problems !!
Common metal ? Dunno . . . . Mine is made of FRP ! Also, it is strange
how you are so touchy about others disagreeing with you but now you
disagree with many others on the list with your profound statement about
'ground loops'. Gee, I hope they don't react like you do !
| Quote: | "With respect" - Thank you for the respect, but all I want is a nation
that
With less respect now Barry, please don't worry about this any more,
I've lost interest in finding out your 'Magic Solution'
To everyone else on the list that has bothered to read this far, please
accept my apologies for being drawn into this. Have been doing long
hours lately and maybe I've just got SOL (Shit On Liver) from "Chop'd
Liver" I'll be over it tomorrow.
Kingsley
DO NOT ARCHIVE
cjensen(at)dts9000.com Guest
Posted: Tue Oct 24, 2006 4:13 am Post subject: alternator autopsy |
Kingsley,
Can you spell N-A-R-C-I-S-S-T-I-C? One word can explain many things.
Chuck Jensen
Posted: Tue Oct 24, 2006 4:47 am Post subject: alternator autopsy |
P.S. You can put another 'I' and 'S' in narcissistic if you wish.
Chuck Jensen
Posted: Tue Oct 24, 2006 4:54 am Post subject: alternator autopsy |
What is it about alternators that generates so much angst?. Every
time this topic comes up, it seems like someone on the list goes
bizonkers. Are these devices invaded by demons, only to be released
every time this topic comes up?
Chop'd Liver, how hard is it to say, "I covered this in a previous
post. Please see the archives"? Geeze, I don't understand the
snotty commentary.
Best Regards,
Steve Thomas
On Oct 23, 2006, at 7:37 PM, FLYaDIVE(at)aol.com wrote:
| Quote: | Because so many of you follow the leader with heads stuck so
place.
Posted: Tue Oct 24, 2006 5:01 am Post subject: alternator autopsy |
That's a tough one, Chuck. You seem to be having trouble spelling it,
too But I couldn't agreee more with your diagnosis-at-a-distance.
M-E-G-A-L-O-M-A-N-I-A.
-Bill B
On 10/24/06, Chuck Jensen <cjensen(at)dts9000.com> wrote:
Kingsley,
Chuck Jensen
