janderson412(at)hotmail.c Guest
Posted: Sat Oct 21, 2006 12:55 pm Post subject: Guy --- Re: Warp Drive Hub |
If you don't set the prop toa degree setting, what dod you use as a
starting datum?
I use an electronic level and sice doing so has made a diff to smoothness
Subject: Guy --- Re: Warp Drive Hub
Date: Sat, 21 Oct 2006 06:55:36 -0400
Guy, please post some pics of the Exhaust There is a length in the Rotax
manual for length from exhaust port to the muffler including the cone( that
is the part that Skystar modified with a few bends as well as chopping off
about 1 " or so of the y pipe manifold but if does seem to work ok.)
Timing etc -- call Rotax Bob Robertson. I have called him for advice many
times and it always free but keep in mind I buy all rotax stuff from him as
well.
I think I read that your engine sat idle over 10 years during build time ?
Possible issues there like crank seals but ask Bob.
Your prop sounds way over propped at your 13 degree setting. What was it
at before you changed it ? . I don't measure my WARP with degrees but set
all the blades all the same. I did measure last week though and I think it
was around 10 degrees or so at the tip . Yours being a 2 inch large dimater
I would stay closer to 10 degrees. ( mine is 68" ) I set by RPM and how
it works but I think WARP should be 10 to 11 degrees area. I used the Warp
protractor thingy and re pitched to all the same. I think I made it 1/2
degree finer approx. and my static went from 5850 5900 to 6150 - 6200 and
my in flight WOT went from 6600 to 6900 or so. I also dropped the clip
on carb needles one notch to the bottom notch so it all the way rich now.
and egts have come down from 1200+ to 1100 or a bit less in cruise. Temps
here are average 30F to 45F degrees this week. and our elevation is about
950 asl.
I would set your prop to give 6200 to 6400 rpm static to start and
coarsen it about 1/4 degree at a time from there as needed. Assuming you
have stock jetting ( I think the needle is a 11G) the clip should be on
second notch from bottom of needle but if EGTS get over 1200 in cruise I
would drop one more notch. I think you said that you have some EIS or
engine gauges etc ? How is the impulse achieved ? A tiny tach will
confirm or an optical tach that your gauge reading is infact accurate. Tiny
Tach --order one from Bob when you call him and he will send out overnight.
EGT confirm it by the look of the spark plugs.
Do you have another 582 owner near you with allot of experience? I would
get him over to help you out as well is possible. Personally I Think you
are getting in way to deep on the technical stuff and you have most likey
some simple issues here to resolve.
dave
Posted: Sat Oct 21, 2006 4:58 pm Post subject: Guy --- Re: Warp Drive Hub |
I set with Warp gauge originally but never set it to any accurate degree -
just all three blades the same
And I just kept changing accordingly about 3 tries and it was good.
I have used a laser as well and it shine on the wall of hangar 25 feet away
and all three blades hit the same spot.
I know know the Warp is around 10 or 11 degrees and a GSC 68" 15 to 16.5
deg is good as well but remember WARP measure angle at tip and GSC part way
in ( maybe about 75% or way out from root , Where ever the GSC protractor
fits tight.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Sat Oct 21, 2006 10:24 pm Post subject: Guy --- Re: Warp Drive Hub |
corrected my mistakes, can't type fast.......
If you don't set the prop to a degree setting, what did you use as a
starting datum?
I use an electronic level and since doing so has made a diff to smoothness
From: "John Anderson" <janderson412(at)hotmail.com>
Subject: RE: Guy --- Re: Warp Drive Hub
Date: Sun, 22 Oct 2006 09:54:26 +1300
starting datum?
well.
950 asl.
Float Flyr
Posted: Sun Oct 22, 2006 6:41 am Post subject: Guy --- Re: Warp Drive Hub |
I'm surprised that Warp sets it's blades by the tip angle. I thought the
greatest action on a propeller occurs at a distance about 2/3the length of
the prop measured from the centre out. Each blade should be measured
independently to locate the place to attach the prop protractor. The tips
of the blades should be a lot finer pitch as the tip speed is considerably
higher.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dosmythe(at)cox.net Guest
Posted: Sun Oct 22, 2006 8:29 am Post subject: Guy --- Re: Warp Drive Hub |
Me too. I found that I have a difference between the blade pitch of up to 1
degree if I use the tips as a reference. Warp strongly disagreed with me
but, So be it. I checked the pitch angle of all three blades every two
inches from the hub out to the tip (after setting the pitch at the 3/4
position). As I neared the last three inches at the tip, the angles started
to drift up to 1 degree in error. All reading from the hub out to that
point were very close. Now, I use the 3/4 position for all my sittings.
Don Smythe
dave
Posted: Sun Oct 22, 2006 9:46 am Post subject: Guy --- Re: Warp Drive Hub |
Don, The WARP protractor fits nicely on the tip and I have had good success
doing it there. are you saying that the blades are not all uniform from
Root to tip ? I have no checked but I might . Did you see my latest
Trailer park video? 17 megs http://www.cfisher.com/kitfox/ if you
think my prop is not working properly , well I hope to get a bit more
performance yet in that case ...... anyone else ever wonder what a
Kitfox has for breakfast ? A Zenith 701
I just new GSC wood blade in last week and anxious to try them out soon on
this 582 Kitfox. My old ones near 500 hours and I figured it time for some
new ones. They sure look good out of the box !!
Now back to Warp prop. I really don't think it matters how you set you
prop as long as all blade at the same pitch , track properly and are torqued
properly and regularly. As long as you get the 6000 to 6200 static rpm and a
decent cruise . Just watch those EGTs.
Dave
http://www.warpdriveprops.com/protractor.html
2. Setting degrees of pitch. ATTENTION! Always set the degrees of pitch at
the tip of the blade! Determine the amount of pitch you want in the
propeller and rotate the protractor wheel the same number of marks from your
starting point. Example: If your aircraft is sitting level, your starting
point would be zero. If you want 10 degrees of pitch, move your protractor
wheel ten marks in the outer scale.
Posted: Sun Oct 22, 2006 10:22 am Post subject: Guy --- Re: Warp Drive Hub |
Unless we have different Warp protractors, the protractor fits anyplace you
want to put it. I'm saying that my blades started to loose uniformity
during the last 2-3 inches of the tips. The blades from the hub out to the
last couple inches were very uniform. That's why adjusting at the 3/4 point
makes good sense to me. That's the point where the prop is developing max
lift. I would think that it's most important for the props to be exact in
pitch at the 3/4 point. You can set the pitch any place you want for your
own day to day adjusting just use the exact same point on each blade. I
forget the exact number but if you pitch one blade at 20" from hub (example)
and another blade at 21" you have just put in a 1 degree pitch error between
the two blades. Again, I checked this but forget exactly how much error but
enough to stress that the exact distance from the hub is important.
It is only my theory but the tips of the warp props are thin and narrow
possibly causing a very slight "warp" coming out of the molds. Ha....That's
why they call them Warp props. This is where Warp Drive told me,
"impossible". To check this on any prop is real easy. Next time you adjust
all three props at the tips simply slide the Warp protractor down the blade
to an exact distance from the hub (around 3/4 length) and record all three
numbers. No matter what the angle, they all 3 should read the same.
Don Smythe
Posted: Sun Oct 22, 2006 5:00 pm Post subject: Guy --- Re: Warp Drive Hub |
Can't see that it matters as it's only a datum to work to. And being at the
end there's no chance of another error between blades with measurement
position . John A.
Date: Sun, 22 Oct 2006 12:10:31 -0230
higher.
Noel
Guy Buchanan
Posted: Sun Oct 22, 2006 5:29 pm Post subject: Guy --- Re: Warp Drive Hub |
At 10:45 AM 10/22/2006, you wrote:
| Quote: | Don, The WARP protractor fits nicely on the tip and I have had good success
Root to tip ?
Mine was off about 1/2-3/4 degree. I first set the tip, then shifted to 3/4
and equalized, trying to hit the mean of all three blades. That way I could
still use the tip angle as reference.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Jim Shumaker
Posted: Sun Oct 22, 2006 5:47 pm Post subject: Guy --- Re: Warp Drive Hub |
Me too Don.
Not only did I find the pitch drifted but also the track changed. I could not track the tips by setting the protactor on the tips but putting the protractor in a few inches the track came in perfect. Thought it was just my mowing the grass with my blade.
Jim Shumaker
_________________ Jim Shumaker |
Posted: Sun Oct 22, 2006 6:29 pm Post subject: Guy --- Re: Warp Drive Hub |
If you use an Inclinometer you can zero it on the hub, then measure the tip
with the blade horizontal. Can get it to within .1 of °.
Subject: Re: Guy --- Re: Warp Drive Hub
Date: Sun, 22 Oct 2006 13:45:11 -0400
Dave
Posted: Sun Oct 22, 2006 10:40 pm Post subject: Guy --- Re: Warp Drive Hub |
Why do Warpdrive insist on measuring at the tip?? I have always done so as
the instruction says and have a nice smooth prop, 72" 3 blade. John A.
Date: Sun, 22 Oct 2006 18:17:21 -0700
success
Root to tip ?
Guy Buchanan
Need more speed? Get Xtra Broadband (at)
http://jetstream.xtra.co.nz/chm/0,,202853-1000,00.html
Float Flyr
Posted: Mon Oct 23, 2006 1:51 pm Post subject: Guy --- Re: Warp Drive Hub |
Most props are designed so the greatest thrust is developed about 2/3 the
way out from the centre to the tip of the blades. This is usually the
widest part of the blade too. The pitch of the blade should thin as you
approach the blade tip as the tip actually travels further per revolution.
Because it also travels faster the tips are closer to stalling at their
subsoni8c speeds. That's just another reason to expect the tips to be
thinner pitch.
In the case of Warp blades... These are composite blades and probably do not
act the same way wood or metal blades will. I guess it is possible that the
tips actually thin out the pitch under load.
One thing I'm sure of is Warp themselves specify measuring the prop angle at
the tips, for their blades that is the way to do it.
Noel
[quote] --
Kitfox III-A
dave
Float Flyr
Posted: Mon Oct 23, 2006 4:29 pm Post subject: Guy --- Re: Warp Drive Hub |
What is your static rpm WOT? Should be around 6200 on wheels ..6400 on
floats.
Noel
[quote] --
Kitfox III-A
dave
Posted: Mon Oct 23, 2006 5:18 pm Post subject: Guy --- Re: Warp Drive Hub |
Same on both counts . if you go for higher static you will run over 7000
WOT and generally too high egts.
Over all Warp a decent prop I have found. I will examine what Don brought
up and and see if there is any differance.
My only beef now is i get about 6900 WOT will static I am just barely 6200.
Needle in carbs set full rich.
I run about 102 to 103 mph WOT on wheels and about 94 to 95 on Amphibs.
I just got a new GSC in 68 inch blade and will try it soon too. I have
always found GSC a good performing prop. I heard once the Jimmy Franklin
refused to use a Ivo on that Skystar video and used the GSC cause of the
flex in a dive might hit the nose cowl. Rumor or truth ? Mythbusters
only know for sure LOL
Dave
Float Flyr
Posted: Tue Oct 24, 2006 7:29 am Post subject: Guy --- Re: Warp Drive Hub |
I think I mentioned I have the three blade Ivo-UL with the electric adjust.
I try not to change the pitch to much in flight. I might thicken it a tad
if I'm on a longer trip. Most of the flying is in an out of fishing holes
and I'm always taking off or landing. I do however find the Ivo very
smooth. If I can ever convince my self that I need a 582 "E" box I'll get
the GSC/Warp ( A GSC adjustable hub with Warp blades) If I get that set up
I may go with a little longer blade too. In the mean time I have a number
of people looking out for a Mercedes Smart car. In Canada all the smart
cars are Diesel. They can be upped to 65 Hp very easily and are almost the
same weight as the 582.
I've also been playing with the idea of an HAC. Have a look at that it's so
simple it's almost obscene.
Noel
[quote] --
Kitfox III-A
occom
Posted: Wed Oct 25, 2006 2:01 am Post subject: Guy --- Re: Warp Drive Hub |
dave
Posted: Wed Oct 25, 2006 2:10 am Post subject: Guy --- Re: Warp Drive Hub |
high altitude kit
dave
actuallly -- high altitude compensator
