Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Tue Oct 24, 2006 6:39 pm Post subject: Dead Horses don't die... |
Apologies to belabor these two points, but another builder I know is dead-set on the ol' Cessna Split Master switch and a separate Avionics master. As a long-time Nuckollhead, my plane is faithfully a Z-11, and electrically all runs, all hits, no errors. My protestations have come to naught despite my best explanations.
The Avionics Master won't die because so many radio makers still insist on them by inclusion in installation schematics and threats of no warranty coverage if not used. (I know this was true of Jicroair when I installed mine, and I have requests out to GRT, Trutrak and Garmin for clarification) I suppose one could feed avionics by connecting a separate fuse block to the normal supply side of the e-bus through an "Avionics Master Switch" and accept the single-point failure potential.
On the split master side, I could propose using the switch, provided crowbar protection and low-voltage monitor/annunciation are employed.
In order to offer guidance, I have searched the A-list archives & AeroElectric Connection website for supporting documentation and found Bob's article on Avionics Masters, but not the critical arguments I have seen for the past six or seven years supporting avoidance of the split master. Can someone please point to specific references?
Sorry for the broad request, but I am trying to spread the gospel here!
Mark Phillips RV-6A with 366 hours of happy electrons...
_________________ From The PossumWorks... |
nuckollsr(at)cox.net Guest
Posted: Thu Oct 26, 2006 6:37 pm Post subject: Dead Horses don't die... |
At 11:06 PM 10/22/2006 -0400, you wrote:
| Quote: | Apologies to belabor these two points, but another builder I know is
coverage if not used. (I know this was true of Microair when I installed
Not necessary. Run your "critical" items from the e-bus and
put a switch in series with the e-bus normal feed path diode
and call it the "avionics master switch". I will write to
Trutrak and Garmin and inquire as to any special knowledge
they have for the evils that lurk on the bus which are held
at bay by the avionics master switch. Anyone laying any bets?
When I wrote the article on avionics master switches over
10 years ago, it had to be noticed by about 130,000 aviation
types all over the world. NOT ONE individual contacted me
to explain where I was wrong or even to complain about
going against tradition.
I know that Microair did not do their homework and build
power handling circuitry that was NOT DO-160 qualifiable
(20v for 1 S, 40v for 100 mS). That's why I stopped handling
them . . . they knew their limitations and in spite of
offers of free help, they elected to drive on as-is.
But that still begs the question:
Assume a radio IS vulnerable to start-up transients,
where is it written that it's better to have ONE switch
turn off all vulnerable radios as opposed to turning each
vulnerable radio off with its own power switch? Just because
there's only ONE switch to 'remember' doesn't make it any
more likely to be operated at the right times. Failures to
observe checklists have been demonstrated innumerable times.
So if you can follow a checklist, turn off devices for which
there are concerns. If you can't follow a checklist, then
no number of switches installed anywhere will be a 100%
prophylactic against gremlins that go spark in the dark.
There is nothing functionally wrong with the split-rocker
switch. It was cleverly conceived when aviation decided to
eliminate the possiblity of leaving an alternator on-line
without also having a battery . . . but being able to run
the battery by itself too.
The S700-2-10 shown in most of the Z-figure master switches
duplicates the split rocker functionality: OFF/BATTERY/BAT+ALT
The split rocker has been elevated to a position of sainthood.
I've seen all manner of toggle and rocker switch installations
on OBAM aircraft where that infernal split-rocker has been
enshrined in a place of prominence on the panel . . . even tho
it doesn't look like any of the other switches.
The point is, if you can purchase the progressive transfer,
ON-ON-ON functionality in the switch style of your choice, then
you need not genuflect before the alter of split-rocker switches
from the certified world. The 2-10 switching protocols do the same
thing in what ever style switch you choose.
Mark Phillips in TN
Posted: Thu Oct 26, 2006 7:22 pm Post subject: Dead Horses don't die... |
In a message dated 10/26/2006 9:42:25 PM Central Daylight Time, nuckollsr(at)cox.net writes:
| Quote: | | Anyone laying any bets? |
Here's response from GRT- not sure I unnerstand it, tho- I have heard that main complaint is that voltage sag whilst firing up the Lycosaur will cause Horizons to re-boot. Doesn't seem like a big problem since by the time you get to run-up all is back to normal. Original request below their response- GRT sez:
"EIS on during engine start is correct, the EFIS system should be off during engine start. The EFIS system has 3 power bus inputs so you could connect DU-1 input 1 to your Endurance bus and input 2 to your Main bus. You would connect DU-2 input 1 to your main bus and input 2 to your Endurance bus. Input 3 on both units could go to a small back up battery. Your AHRS inputs would be the same as DU-1. There are many ways to go on this."
bicyclop(at)pacbell.net Guest
Posted: Fri Oct 27, 2006 12:20 am Post subject: Dead Horses don't die... |
Our RV was wired something like this when we got it - with a switch
labeled "E-Bus" but which I thought of as an avionics master because the
radios wouldn't come on without it even with the master on. In fact it
was a switch/breaker. When I recently remade the panel, that same
switch/breaker fell apart in my hands while I was removing it from the
old panel. A single point of failure which, fortunately, failed on the
ground. There was an alternate feed switch, so I guess the switch
failure wouldn't have been a horrible thing in flight, but none the
less, I didn't include it in the new version of the panel. I figure that
it can't hurt to exercise all the radio switches regularly anyway so we
switch them off after each flight.
We do have a couple of items that don't like being on during engine
cranking. One is a Dynon D-10 which browns out and sometimes doesn't
come back so we've put an item in our checklist to pull its breaker
before start. The other is a Trio autopilot which the installation
instructions state not to subject to the reduced voltage of cranking so
we switch it on after startup. Some stuff is still out there that need
some kind of protection to avoid problems.
Pax,
Ed Holyoke
<nuckollsr(at)cox.net>
| Quote: | fuse block to the normal supply side of the e-bus through an "Avionics
khorton01(at)rogers.com Guest
Posted: Fri Oct 27, 2006 1:31 am Post subject: Dead Horses don't die... |
On 26 Oct 2006, at 22:34, Robert L. Nuckolls, III wrote:
I've got a Microair com in my not-yet-flying aircraft. I don't have
an avionics master. What sorts of problems can I anticipate due to
the power handling issues? Do I need to have the radio OFF during
start up and shut down?
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Fri Oct 27, 2006 1:39 am Post subject: Dead Horses don't die... |
On 26 Oct 2006, at 23:21, Fiveonepw(at)aol.com wrote:
[quote] And here is response from Garmin- again, original request below:
"Garmin recommends that these units no be power up during engine
start to
prevent voltage spike damage. "
George Koelsch
Garmin International
Aviation Field Service Engineer
george.koelsch(at)garmin.com
913-397-8200
Mark Phillips in TN
Posted: Fri Oct 27, 2006 4:02 am Post subject: Dead Horses don't die... |
In a message dated 10/27/2006 4:35:56 AM Central Daylight Time, khorton01(at)rogers.com writes:
| Quote: | What sorts of problems can I anticipate due to
start up and shut down? |
"Radios ON/OFF" are checklist items for me- haven't seen any negative effects from radio yet when "OFF" item missed, but T2000 xpndr does seem to behave oddly if left on at shutdown. "No Comm" errors, turning itself on before Master shut off, difficult to turn on (occasionally requires several attemps holding power button in) but otherwise seems to work fairly well.
My 760 transmits very well, but reception from maybe 20% of other aircraft (ATC and unicoms always come in well) typically with older radios, is garbled in varying degrees and on rare occasions almost non-existent. Haven't been able to resolve yet- curious if others experience this. Close formation reception is often garbled- added resistor to antenna line as discussed here some time ago (thanks Bob!) helped quite a bit, but will upsize resistor at next opportunity & see if improves...
Mark Phillips -6A, 360 hours
Posted: Mon Oct 30, 2006 5:57 pm Post subject: Dead Horses don't die... |
Kevin Horton wrote:
<khorton01(at)rogers.com>
Ottawa, Canada
I'm flying a 15 year old -4 that I've owned for 3 1/2 years. It's got a
dirt simple electrical system with a Microair comm that I never turn
off. I'm not proud of it, but there...I've admitted it. No problems so far.
Charlie
Posted: Tue Oct 31, 2006 5:48 am Post subject: Dead Horses don't die... |
Kevin
It's got a dirt simple electrical system with a Microair
comm that I never turned off. I'm not proud of it, but
there...I've admitted it. No problems so far. . .
Charlie
And there's no particular reason to expect problems.
The fact that MicroAir products have successfully survived
all these years in hundreds if not thousands of airplanes
is largely due to the fact that the dreaded and much touted
startup spikes simply don't exist. The DO-160 rationale
for transient withstand has to do with ability to survive
the abnormal conditions of alternator runaway and/or
alternator load-dump transients.
Very few folks experience such events but if they do,
it's while things are expected to be operating normally
and the radio is ON. No amount of avionics master switches
or observance of checklists will provide protection
from these events. This is why the industry recommends
designing and testing to those qualities.
If I were to exercise the-best-we-know-how-to-do in
the purposeful installation of sub-standard accessories,
I suppose we could fabricate some sore of protected
power conditioning system that would provide voltage
limiting friendly to our relatively fragile purchases.
But as many, many users have noted, the risk are low
and adding such features to the system as Band-Aids
is not good engineering.
Don't loose any sleep over your MicroAir accessories.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Wed Nov 01, 2006 6:47 am Post subject: Dead Horses don't die... |
At 08:00 AM 10/27/2006 -0400, you wrote:
| Quote: | In a message dated 10/27/2006 4:35:56 AM Central Daylight Time,
fairly well.
experience this.
Hmmm. . . it would be really interesting to bench check
some of these "problem" radios. I think I'll put a nice
signal generator in my letter to Santa Claus.
| Quote: | Close formation reception is often garbled- added resistor to antenna
Let us know what size resistor you ultimately find adequate.
Thanks!
Posted: Wed Nov 01, 2006 6:50 am Post subject: Dead Horses don't die... |
Inquiry:
I have on order from an avionics installer a GNS430, SL30 and
GTX327- I wish to avoid a separate avionics bus and plan to power these
from my
endurance bus fuseblock, which is hot whenever the master contactor is on per
Bob Nuckolls' AeroElectric Connection system architecture. Is this
acceptable or must I make sure these units are not powered up during engine
start?
Interesting. The installation manuals for the GNS-430 and the
GTX-327 claim DO-160 Category A qualification for voltage spikes (I
don't have an SL-30 Installation manual to look at). Are they saying
that they don't trust their test results, or that they didn't really
do the test? Or that they think the real world might be worse than
the DO-160 requirements?
Ottawa, Canada
Funny you should ask. I've asked it dozens of
times over the years of various promulgators of
avionics master switches . . . I've yet to received
a reasoned reply.
